Liked 4 Times in 4 Posts
I am running a mickey thompson 29.5 x 9 st slick and was wondering what the minimum clearance between the slick and the leaf spring with the car sitting on the ground. thanks ron
Liked 346 Times in 126 Posts
Bias
Liked 226 Times in 115 Posts
With our radials we have 3/8" clearance & have no issues with rubbing.
While it has been many years since we have run bias slicks. It seems like we had about 1/2" clearance, but also had signs of slight rubbing. I'm sure it was due to turning off at the end of the track & sidewall flex. |
Liked 125 Times in 33 Posts
Currently operating Hoosier 9x29 bias ply with about 3/8-1/2 inch clear of the leaf spring. Typically inflated to 12-15 psi on a 9 inch rim. Seems to work fine. The inboard white letters aren’t so white anymore but attribute that to minor rubbing during turns-like 1700camaro alluded to.
Liked 3,205 Times in 977 Posts
All sounds like good guidance, assume you’re running a 10 inch rim?
currently running a 9" rim.
