Old 03-26-2024, 02:59 PM   #21
JP1738
JP1738's Avatar
Liked 1,236 Times in 350 Posts
Default Re: water pump drive vs electric pump
Originally Posted by goinbroke2 View Post
Thanks for all the replies guys, I'm getting a pump drive from a local S/SS racer. Maybe down the road I'll try an electric pump but I still think it would look silly having a "race" electric pump on a 302 2bbl, LOL!!!!
I'm with you, but I already had one as a spare for my super gas car so I used it on my 305 station wagon. Busted off a smooth -.19 12.80 with a race water pump lol. And the one I have is a CSR I bought new for like $130.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 03-26-2024, 08:34 PM   #22
goinbroke2
Liked 404 Times in 158 Posts
Double post
Old 03-26-2024, 08:48 PM   #23
goinbroke2
I got the pump drive all installed and then to wire it, decided to run a 30A in line fuse and a relay to power the pump and the electric fan. Both on or both off, not sure if I'll like that but there it is.
Relay on right shock tower,
Old 03-26-2024, 10:10 PM   #24
Rory McNeil
Personally, I always run the water pump separately from the fan. When you are warming up a cold engine, no need to have the high draw of the fan going, slowing down the warm up. Plus I don`t run the fan going downtrack, blowing hot air back towards the carb.
NHRA 6390 STK
M/S 85 Mustang
Old 03-26-2024, 10:27 PM   #25
GTX JOHN
We use the blower motor belt pump on my boy's Stocker and it
cools as well as my aftermarket pump and electric fan.
Plus it draws less than 1/2 the amps even running the fiberglass fan
than my Pump/Fan setup.
We have aluminum Radiators on both cars. Perhaps the aftermarket
pumps circulate to fast?
John Irving
741 Stock
741 Super Stock
Old 04-09-2024, 04:17 PM   #26
goinbroke2
I'm thinking I'll change it, not sure when. It's operating now, fine tune later.....does that sound like I'm rushing?? lol.
Jim Miller
103 U/SA
Old 04-09-2024, 08:26 PM   #27
Coleydog
Liked 53 Times in 38 Posts
I had a 2 speed motor from the junk yard but dang I can’t remember what it was off of. Just make sure it has a 1/4” shaft, I even sourced the cog and belt from ‘Mr Gasket’ then made a simple aluminum bracket. Never bought one new in over 50 years. Go to swap meets there’s usually 2 or 3 on a table for 10 bucks.
Old 04-10-2024, 10:17 AM   #28
curtis reed
Liked 125 Times in 59 Posts
5/16" shaft is what's needed.
curtis reed is offline   Reply With Quote
Old 04-12-2024, 04:46 PM   #29
goinbroke2
Even better, had a local Stocker guy that had a spare he could let go for a good price!
(Thanks again Rory)
Jim Miller
103 U/SA
