Liked 427 Times in 97 Posts
Looking for suggestions or part # application for a Pitman arm to install a Vega steering box in a 1970 Chevelle, SS
TIA Greg |
#2 | |
Liked 520 Times in 176 Posts
I believe Flaming River builds & sells steering box's , Vega style - you might want to try contacting them. I know they used to sell parts through Jegs and could be another outlet to try. Hope that helps. Have a Good Day. Respectfully, Henry Kunz 1534 H/SA |
Liked 706 Times in 283 Posts
Speedway has two styles. A straight and a bent one. Not sure if they work for A body
#4 | |
1- FR1500 Steering Box $560.00 1-FR 1722 Upper joint $102.50 1-FR 1715 Lower Joint $100.50 1- FR 1850-22 Steering Shaft $90.00 Total Spent $860.00 Tech Department at Flaming River wasn't much help, They told me my existing "Pitman arm" would work! Not even close! Thanks for the Reply! |
Liked 285 Times in 87 Posts
Greg... Contact Rare Parts Steering and Suspension in Stockton, CA. They will "steer" you in the right direction. MB
Liked 133 Times in 76 Posts
Is the shaft for the pitman arm smaller than the hole in the pitman arm? I used an S10 box on my 85 F body and pitman arm worked. You might need an arm from a manual steering Chevelle.
UPDATE: B/SA Bob Moran "modified" a new "Straight" Vega Pitman Arm, and a "used" pitman arm from a Monza to make it fit.
Furthermore the upper "DD" Joint that was sugested to purchase was the wrong size! fortunately for us, Milt @"Westgate Performance" in Freetown MA. had what we needed "IN STOCK" in order to complete the installation........ |
Liked 759 Times in 379 Posts
Sounds like a huge PITA to lose a few pounds.
