Old 04-11-2024, 11:38 AM   #1
AveryMcLawhorn
Liked 80 Times in 19 Posts
Default 1966 Chevy II Front Shocks
Hi All,
What are people doing to get adjustable shocks on the front of a 1966 Chevy II? Is there an adapter kit made for the lower spring perch to change the type of shock mount? The Chevy II has two stud mounts that goes through the center of the spring on control arm in the spring perch. I am not finding many of any options for adjustable shocks that fit the factory mounting style.
Thanks
Avery
Avery G. McLawhorn
2166 Super Stock
AveryMcLawhorn is offline   Reply With Quote
Old 04-11-2024, 11:52 AM   #2
James Perrone
Liked 1,861 Times in 434 Posts
Default Re: 1966 Chevy II Front Shocks
QA1. That what I have
I have a set of koni 90/10 I’m not using
james perrone 1290 STK
Old 04-12-2024, 07:43 AM   #3
dillman31
Liked 6 Times in 6 Posts
Get you a set of these. Then you will have more shock options. I run Afco's on mine.
https://mprracecars.com/partinfo.php...tedpartid=1010
dillman31 is offline   Reply With Quote
Old 04-12-2024, 05:28 PM   #4
I used to put regular T bottom shocks on my Chevy II's
Two 5/16" bolts up from the bottom, with double fender washers, and a check nut. Now you have two studs sticking up . ;-)
