Liked 30 Times in 19 Posts
I have 402 stocker engine that seems to have a lot of blow by. Having build this engine several years ago . it is a 454 block sleeved back to a 4.185 bore. Cp piston race rings honed the first time sv 10 diamond stone sealed up made reasonable power. Hauled it back to sd where it sat for 3years in the shop. Was going to sell it so put it on engine stand and ran it smoked out of the valve covers a bunch. So I took it apart had it honed. Reassembled it new with race rings ,put it on the engine run stand same thing. Took apart once agin. Took it to victory engine had it honed once more . New pistons and rings etc. I look the engine over upped the oil the ring thing still smokes out the valve covers. Not a little a lot. Any ideas?
Liked 225 Times in 136 Posts
Check it with a good Blowby meter! Then you will know!
Liked 1,470 Times in 308 Posts
Take the engine back to Matt's shop and put it on the Dyno, he'll figure
it out quickly. J.R. |
#5 | |
Liked 520 Times in 176 Posts
Since you recently had this engine honed and re- ringed it, have you made any full power pulls on a dyno ? It'll take a couple of pulls to get the rings to seat. Running at Idle or above Idle won't seat the rings. Also what shape were the ring lands in ? If they have a excessive amount of play ( up & down) they won't seal either. If you haven't run this engine on the dyno, I would, then make at least 4 or 5 full power pulls and that should get things in order. Good luck with your adventure and keep us posted with your results. Respectfully, Henry Kunz 1534 H/SA |
#6 | |
Liked 54 Times in 18 Posts
Ive seen small casting flaw holes in cylinder heads or intakes suck in oil when I was a dealership mechanic. Its rare but it happens
Liked 348 Times in 152 Posts
Yup, pull the intake if needed and look at the backside of the intake valves for any "puddled up" oil, or oil tracking in the runner. Then check the angles to ensure they match.
Phil Molski PMR Performance S/C 1623 |
