Old 04-19-2024, 09:40 PM   #21
Liked 1,892 Times in 423 Posts
Default Re: 402 stocker engine
Again, if it isn't smoking out the headers, oil isn't getting past the oil ring, or second ring. If it is smoking and "huffing" out the valve covers/breathers, that's cylinder pressure in the pan, and it may not show up on a compression test or a leak down. But it WILL show up on the dyno, or in the car, with a Dwyer gauge on the breather. If you don't have access to a dyno (an 8 hour drive to get on a dyno is a "no brainer", these days there is no substitute for a dyno for a race engine) you can test it in an automatic car, with two people.
If you have any sort of gapless ring, a leak down test can lie to you.
Old 04-19-2024, 11:31 PM   #22
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Toy... Something I continue to do is when the block comes back from the Machine Shop, I still wash the engine and most importantly the bores with a bucket full of hot water and Tide Laundry Detergent. It is amazing how black a rag will get scrubbing the walls. I finish up with a scrub brush. I believe the bore finish can't be clean enough, I normally wipe ATF on the bores, when dry to keep from rusting. We have never had any ring seal issues, causing high crankcase pressure. On the Dyno 5 pulls is what it takes, to have stable results.
One thing I have had happen is the valve seals have come off the intake guides. They then run with the valve and the seal actually acts as a pump, pumping up against the top of the guide, allowing oil the enter the valve pocket. This results in the backside of the Intake Valve being oil soaked and allowing oil to enter the Combustion Chamber causing embarrassing smoke clouds. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 04-19-2024, 11:45 PM   #23
Jeff Stout
Liked 706 Times in 283 Posts
The shop doing the hone have they checked the cylinder roughness with a profilometer? The intake gasket not soaked at bottom near intake runner?
Old 04-20-2024, 09:14 AM   #24
Ralph A Powell
Liked 225 Times in 136 Posts
I have a Fisher Porter blow by meter it is the same model Chrysler used that is where I learned how to use mine from Don McElory Ted Flack and John Worley! The company that bought Fisher Porter still has them available. They are more accurate than the Dewyer Plastic meter that Speed is pushing I tested them back to back when Hamburger was selling the Dewyer!
Old 04-20-2024, 03:01 PM   #25
TILBURG
Liked 79 Times in 7 Posts
Did someone put the ring spacer on the bottom people seem to struggle with that.
TILBURG is offline   Reply With Quote
Old 04-20-2024, 10:05 PM   #26
Jrh5220
Liked 34 Times in 21 Posts
Question Re: 402 stocker engine
Originally Posted by Jeff Stout View Post
Not sure if anyone else ask this. Do you know the tension on oil ring?
The other would be seating the rings. Either on a dyno if in car then maybe get brake pressure as high as you can and run motor in gear as high as you can. If unable to hold in 1st gear try second gear. I had trans brake on my super stocker and it worked well on rebuild. Don't forget to remove rpm chip. Hopefully carb is not leaking when sitting and washing out cylinders.
Jeff it’s about 14 lbs
Jrh5220 is offline   Reply With Quote
Old 04-20-2024, 10:08 PM   #27
Jrh5220
I did that years ago, but these piston have none, simple 5/64 5/64 3/16. ?
Old 04-20-2024, 10:16 PM   #28
Jrh5220
Originally Posted by Hacksaw View Post
Check at the base of your spring pockets.
They have never been cut factory shock. To Hacksaw it acts like the cam is going flat,thats what it looks like but the cams fine?
Old 04-20-2024, 10:38 PM   #29
Jrh5220
Originally Posted by Bob Sherwood View Post
Do you know what brand and material the sleeves are ?? curious -- thanks
Melling cast. Have done about 10 of them over the years,this is the only one to do this.
Old 04-21-2024, 10:32 AM   #30
B Parker
Liked 2,343 Times in 465 Posts
Not sure why you are doing this on your own. The first time you had this problem you should have brought your entire engine to the shop and let them figure out what the problem is. We all could guess at 20 different things it could be but until you bring it somewhere good you could hone this block right into new sleeves. I'd call the guy 5 post up and ask him if he has time to look at it. It's great to say you did it yourself or you don't have the money but at some point you need to stop the bleeding. BP
