#31 | |
Liked 32 Times in 21 Posts
#32 |
Liked 799 Times in 236 Posts
Jim, when you say they are race rings...are they AP steel.coated rings, a barrel faced back cut moly, etc?
"That'll never work....." |
#33 | |
Liked 520 Times in 176 Posts
Something Alan said struck me, as we might be looking at this all wrong. What kind of an oil pump are you using? The reason I ask is it possible that the oil pump in pumping a great deal of oil up to the rocker arms and flooding the valve cover area and I'm going to guess that you aren't using a valve stem seals on the exhaust valves. If you have excess oil in the valve covers and you don't have exhaust valve seals, while the engine is running the puffing through the breathers could be caused by oil blown back from the exhaust stems. Take a valve cover off and remove the distributor and install an oil pump priming tool. Put a 1/2" drill on it and spin it up, then observe the amount of oil being pushed through the pushrods and out the rocker arms. You might be surprised how much oil can flow through there. I have a Schumann pump in my engine and it does a VERY Good job of oiling the engine. When I first primed my engine the oil shot out the rockers like I never saw before. I had to restrict the oil flow and got that under control. I'm not saying that's your problem, but lets assume just for a moment that with the pistons and rings being new and good quality and you've had this engine apart a couple of times, maybe its not the rings or pistons or even the cylinder sleeves. but we're looking in the wrong place. I still believe you should put this engine on a dyno at this point and put this situation to rest. On a dyno you'll also know just how much Power this puppy makes. The best of luck on you're search here, keep us informed as to what your conclusion is. Respectfully, Henry Kunz 1534 H/SA |
#34 |
While the #401 heads are notorious for poor oil drain back, the haze from the lifter valley area (coming up from the crank case) doesn't fit with that either.
Tough to diagnose stuff like this long distance. If the leakage numbers are in fact fine, the dyno is where you'll find the answers.
#35 |
#36 | |
#37 |
Liked 1,880 Times in 422 Posts
Oil temp is not hard to measure, you can put a cheap sending unit in the drain plug.
Alan Roehrich 212A G/S |
#38 |
Didn't mean to offend you, Jim...just trying to pull out some info (ring material, etc).
Wishing you all the best as you work through it. -Al
"That'll never work....." Last edited by Alan Nyhus; 04-24-2024 at 08:57 AM. |
#39 |
Liked 73 Times in 37 Posts
The part that doesn't sit right with me is that it sat for 3 years, and somehow became a smoker
#40 |
