Old 05-19-2008, 08:01 PM   #1
T Hall
T Hall's Avatar
Default Complete 434 and 358 roller motors
434 Small Block Chevy complete Roller Motor. Here's what you get. GM Block with SPLAYED MAIN CAPS, Eagle 4340 Crankshaft, Lunati Pro Mod Rods, JE 13 to 1 Compression Pop Up Pistons, Block is Filled, Air Flow Research ALUMINUM Cylinder Heads AFR 2.100 intake valves and 1.65 Exhaust valves, NEW Roller Valve Springs and Guides, AFR Stud Girdles, Lunati ROLLER CAMSHAFT .656 Intake Lift and .668 Exhaust Lift, Lunati Roller Lifters, Comp Cams Pro Magnum Roller Rockers, Jesel Belt Drive (With a NEW BELT) NEW $250 dollar set of Total Seal MAX SEAL Piston Rings, NEW 77H Race Bearings, (Rods and Mains) 7 quart Moroso Oil Pan with Windage Tray, Canton Aluminum Reusable $100 dollar Oil Filter, Edelbrock Intake, MSD Crank Trigger Distributor, and Spark Plug Wires, NEW Spark Plugs, ATI Super Damper, SFI Flexplate, Motor is Primed and Ready to go.
Must sell $7200 obo
COMPLETE 358 Small Block Chevy Roller Camshaft Motor. Fresh Bearings (H) and Molly Rings. 4 Bolt Main Block, Brodix - 10 Aluminum Heads, Manley Valves,Comp Cams Roller Valve Springs, Comp Cams Push Rods, Comp Cams Roller Rockers, Stud Girdles, Ross Pistons, Manley H Beam Rods, Eagle Crankshaft, Completely Balanced, Lunati Roller Camshaft 640 int / 642 exh., Moroso 7 Quart Oil Pan with Widage Tray, Edelbrock Victor JR Intake, Erson Gear Drive,
$4400 obo
ALL FRESH AND READY TO RACE.
Call DICK HALL
at (740) 927-0770
ebay pics and info
http://cgi.ebay.com/ebaymotors/ws/eB...m=160241648443
http://cgi.ebay.com/ebaymotors/ws/eB...m=350061218275
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
Search this Thread:
Advanced Search
