Liked 430 Times in 214 Posts
Can anyone with the true tech knowledge (or not, since we all are subject to it's use), please explain the Compulink AUTO Start System once it is armed to the :ON position in as much detail as you can. (And if your name is Jeff Foster, your input may be especially valuable in this conversation...).
And does anyone know when it was first introduced and adopted by NHRA for use in competition? And, though the Starter activates the system after both competitors are pre-staged, when does the timer start the 10 second (Sportsman), timeout countdown, after how many bulbs are lit (in our case of course the Upper Blue LED Rainbow and center White LED Line represents Pre-Stage, and Lower Blue LED completion of the circle represents Fully Staged). I know the answers to all 3 questions above. I will pose the final question after a reasonable period of time has elapsed so that many with knowledge and wish to, have chimed in and responded, and please help participate, it may be important to all of us...And that final question I will pose later, I do not know the answer to. But, we all should. My thanks to all that contribute to the thread in advance!
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 05-02-2024 at 04:40 PM. Reason: Correction |
Liked 4,388 Times in 504 Posts
For sportsman, it is 10 seconds to timeout and it starts when 3 bulbs are lit.
Hiya Bobby and TY.
That answers questions 1 & 3, but not when it was instituted by NHRA, which is question 2. And thanks for the correction on seconds to timeout, different than the pros use. I appreciate your input Mr. Fazio!
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 05-02-2024 at 04:31 PM. Reason: Correction |
Liked 609 Times in 140 Posts
I wish I could give you an exact date but it's something about the first thing to go...
It came into place and Jeff and I had lengthy conversations about it towards the end of my reporting for DRC. So that would be very late 90s or very early 2000s. |
Liked 708 Times in 285 Posts
I could switch on even if cars are in water box. But I don't until track is clear. Tree takes over a that time. I actually thought 3 bulbs on and it's 7 seconds. Sounds like I'm wrong.
I thought it was 7 seconds as well.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
Liked 2,516 Times in 701 Posts
We had a discussion at LVMS last race and they informed me
it was 10 Seconds.
#9 | |
Liked 759 Times in 379 Posts
10 seconds is for bracket/handicap tree, 7 seconds is pro tree BUT when racing at a new track to you, confirm with track management before your 1st hit. Last edited by 1320racer; 05-03-2024 at 12:43 PM. |
Liked 1,330 Times in 361 Posts
I'd be grateful if someone could explain to me how people can get timed out after 1 or 2 seconds if someone turns on a stage bulb (lighting 3 bulbs total) and turns it back off. Something about it starts the autostart and doesn't reset after the stage bulb is knocked back off and both drivers are pre-staged again. Seems to me like it would reset when it sees 2 bulbs again but apparently it doesn't. That's how dragster drivers are able to turn the wheel and dick people who won't stage straight away.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
