Old 05-20-2008, 01:09 AM   #1
Frank Allen
Default 1970 Camaro Stock Eliminator roller
1970 Camaro Stock eliminator roller $9,980. The car has been stripped and sandblasted and painted in GM semigloss black primer. Car is currently rolling on stock rearend and leafsprings.
Chromemoly cage
Chromemoly front strut bars
Chromemoly rear shock braces
Welded in custom subframe connectors
Custom fuel cell
Custom transmission crossmember
New GM Grill
New Calvert split leafsprings
New power disconnect switch
New Carpet, dash pad, front seats, door sills from PUI Interiors
Powder coated front & rear bumper
Powder coated hood hinges, and engine bay bars
Three piece and single piece spoiler available
All glass (Front, rear and door)
Used BG 280 Fuel pump, BG 5000 fuel filter and regulator
Used Holley Annilihator Ignition system, coil and control pad
Used VDO Oil pressure gauge
Used 28" Goodyear front runners
Used 30" Hoosier Drag Slicks
Used Quickcar battery cables and connectors
Used Comp Cams .520/.520 solid lifter camshaft
Used Crower steel rods 6.135
BBC 402 four bolt main block, line honed and bored .060
GM Forged steel crank 20/20
Lightweight GM doors
This car just came beack from the paint and body shop this week, we are installing parts on the car as you read this thread. Please call for picutes or questions, we where building the car to run A,B, C/S or Topstock many other classes available as a smallblock.
We may consider selling some of the parts seperate so call if you have questions.
Frank Allen 402-331-4769
Frank Allen is offline   Reply With Quote
Search this Thread:
Advanced Search
