Old 06-11-2024, 07:07 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default LS/SBC parts - Wheels, Converters, misc
Weld Alumastar 15 x 12 rear wheels with 4.75 pattern and 3” BS. $800.00. Very good condition, no screw holes
Precision Performance Products Kwik shift I manual shifter – excellent condition – no mounting plates. Black. 3 speed, push to shift with clean neutral. $350.00
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel Dogbone lifters LFD-44002 .842 Diameter – set of 16 – $800.00
LS Bryant crankshaft – 4” stroke – 58x - $2800
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1200.00
Forged small journal 327 GM crankshaft. Offset ground (.020 under) by Shaftech. 1.979 rods, 2.300 mains – 3.263 stroke $750.00
Oliver I beam 5.7 rods set of 8 (was used with Shaftech crank above)
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$800.00
8” ATI converter - Flashed 6500 behind 427/430 LS Combo –Powerglide spline - $500
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Wilson 1” 4 hole aluminum tapered spacer – Dominator flange PN 024110 - $150 used for test only
6.00 12 bolt ring and pinion. Ring gear has been backcut - less than 10 runs $250.00
Polished fabricated valve covers with baffles tall - $100.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $300 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150
JRI 2010-2015 Camaro front struts $500.00 used.
1 – Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
Pit Pal Pit Ramps 280 with vertical storage pouch for trailer
Aluminum, 24.00 in. Length, 8.00 in. Width, 2.75 in. Height, Pair with pouch $200
Jerry Bickel Pit ramps and trailer pouch $120.00
Can bring to Norwalk National event
260-223-0157
superstock@live.com
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Old 06-13-2024, 07:54 AM   #2
BZenzen
BZenzen's Avatar
Liked 474 Times in 83 Posts
Default Re: LS/SBC parts - Wheels, Converters, misc
Hi Jeff, is the shifter for a TH 350? FWD or Reverse valve body? Thanks!
Brian Zenzen
SS 5404
STK 5401
BZenzen is offline   Reply With Quote
Old 06-13-2024, 08:00 AM   #3
JeffM
Any 3 speed transmission with clean neutral all the way forward. Push to shift. Park is all the way in the rear P, R,1,2,3,N. Cable exits in the rear.
Jeff Myers
SS3254
S1522
Old 06-30-2024, 01:42 PM   #4
Cody Phillips
Liked 41 Times in 15 Posts
Jeff sent you a text about the shifter and LS ATI converter
Phillips auto body Custom paint
Lumberton, NC
910-739-7171
Cody Phillips is offline   Reply With Quote
Search this Thread:
Advanced Search
