Old 06-19-2024, 02:28 PM   #1
cummins
Liked 27 Times in 8 Posts
Default Air shifter
For ss 904 is there a air/ electric / nuclear/ mind controlled/ shifter that works with a tran brake/ clean neutral valve body
cummins is offline   Reply With Quote
Old 06-19-2024, 05:25 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,199 Times in 977 Posts
Default Re: Air shifter
PPP w/ clean neutral and air shifter works great on my 904.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-19-2024, 06:32 PM   #3
Charlie Walc
ppp co2 with biondo controler
Charlie Walc is offline   Reply With Quote
Old 06-20-2024, 12:20 AM   #4
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
M&M shifter w/air will work great also
Jason Shepard is offline   Reply With Quote
Old 06-20-2024, 07:26 AM   #5
cummins
thanks all
Old 06-20-2024, 08:14 AM   #6
jmcarter
jmcarter's Avatar
Paul Forte was also working on a clean neutral version, you might call TurboAction if you can?t find a PPP. Brad and his Dad worked tirelessly to keep up with demand, IMO the M&M represents patent infringement. It?s been a while since I?ve talked to Brad but his tech support was awesome in fixing an issue I had with a unit installed by a previous owner.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-23-2024, 10:57 AM   #7
Jason Shepard
Patent infringement for M&M? Please explain...
Old 06-23-2024, 03:55 PM   #8
jmcarter
jmcarter's Avatar
IMO their similarities are significant enough to say they copied an existing design without introducing any enhancements to that design. If that?s not the case I?m receptive to being corrected ( I?ve been married for almost 50 years so definitely not adverse to correction).
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-23-2024, 05:07 PM   #9
Jason Shepard
Haha, point taken.
To which company are there similarities? It doesnt matter to me either way, I have one already, i just was curious
Old 06-23-2024, 05:48 PM   #10
jmcarter
jmcarter's Avatar
Brad Ochampaugh and his Dad developed the PPP over 30 years ago and it?s proven to be the dominant shifter in this application, subsequent similar offerings from other manufacturers should have expressed licensing agreements which I don?t think is he case in this instance.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
