Old 06-21-2024, 09:38 AM   #1
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Default Oil Accumulator Solenoid Valve
I am installing a Moroso Accumulator in my stocker and am looking for a cheaper option than the Moroso or Canton solenoid valve to activate it.
Has anyone used anything else or are these two the most reliable options out there?
Thank you in advance.
Thomas
NHRA 1959 E/SA
Cdncarnut is offline   Reply With Quote
Old 06-21-2024, 10:29 AM   #2
curtis reed
Liked 126 Times in 60 Posts
Default Re: Oil Accumulator Solenoid Valve
My opinion having the Moroso valve, it's the best option. You could just use a ball valve and turn it on in the morning and off before shutting down at the end of the day. Cheapest option but not near as effective as pre-oiling at every start up.
curtis reed is offline   Reply With Quote
Old 06-21-2024, 10:32 AM   #3
Steve Grady
Steve Grady's Avatar
Liked 170 Times in 55 Posts
Thomas, You have a PM.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 06-21-2024, 11:26 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Cdncarnut View Post
I am installing a Moroso Accumulator in my stocker a.
why?
Old 06-21-2024, 11:32 AM   #5
Cdncarnut
Cdncarnut's Avatar
Originally Posted by 1320racer View Post
why?
Because it looks pretty under the hood?
Thomas
NHRA 1959 E/SA
Old 06-21-2024, 01:30 PM   #6
mmacd
Liked 2 Times in 1 Post
I used a standard 12v oil compatible solenoid valve. No fuss, no muss. Available from any hydraulic supply company.
mmacd is offline   Reply With Quote
Old 06-22-2024, 08:25 AM   #7
Chevy55
Banned
Liked 179 Times in 89 Posts
why?
Because you can run a lower oil level in the pan and still be safe.
I don't believe in prelubing an in service engine, I'll start the engine with the valve closed then when the engine is warmed up slowly open to avoid a sudden drop in oil pressure and then leave the valve open the rest of the day
Chevy55 is offline   Reply With Quote
Old 06-22-2024, 01:48 PM   #8
1320racer
1320racer's Avatar
You must know something this world champion and his top in the class engine builder don't
Yep, no accusump, how does Tilburg do it? and the emmons boys are known for wheelies and hard braking.
Nice job guys!
Old 06-22-2024, 02:54 PM   #9
Cdncarnut
Cdncarnut's Avatar
Nice job guys!
And that is why I did not answer your question...
Thomas
NHRA 1959 E/SA
Old 06-22-2024, 04:34 PM   #10
Chevy55
Banned
And what would that be?
