Old 06-20-2024, 04:22 PM   #1
Default 302 F-F-Ford Blocks
Which ones are best?
What overbore size is safe, absent a sonic tester?
What thickness would you like to see, with a tester?
(for a Stocker)
Early?
Middle years?
Roller blocks?
Asking for a friend , who knows as little as I do on the subject. ;-)
Old 06-20-2024, 04:41 PM   #2
BRETV
Liked 776 Times in 199 Posts
Default Re: 302 F-F-Ford Blocks
Roller blocks are junk. We used older 302 blocks and set them up for the roller lifters and Hard Bloked them. My last Super Stock motor we used a new Boss block. Biggest we've gone is .060. I've never seen any testing #'s. Would sure have liked to though. 28 oz stuff is faster than the 50 oz newer stuff.
Bret Velde
2003 I/SA
BRETV is offline   Reply With Quote
Old 06-20-2024, 05:14 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Dart SHP or Boss block. Boss block cylinders are shorter than Dart.
Old 06-20-2024, 06:55 PM   #4
Kirk Morgan
Liked 81 Times in 45 Posts
The blocks made in Mexico are slightly better the the roller blocks and about the same as the pre-roller blocks.
Kirk Morgan is offline   Reply With Quote
Old 06-20-2024, 08:32 PM   #5
Okay, thanks
I just spent a half hour reading about Mexican blocks.
Some claim they are 10 pounds heavier, because of the beefier mains.
Everyone seems to want them for strokers.
Nobody, and I mean nobody even mentions the wall thickness.
Not really surprised.
Anyone ever sonic a Hecho in Mexico block?
Old 06-20-2024, 10:09 PM   #6
Joe Strunk
Joe Strunk's Avatar
Liked 5 Times in 3 Posts
We used the Mexican Blocks with Block fill .060 over is about max
Early blocks prepped this way are good to +/- 500 HP
The beefy aftermarket stuff is way to heavy and is overkill for the HP
A4 about the Best but hard to come by
The Later Ford BOSS blocks are good for the weight but $$
I have a standard bore BOSS service block I may be willing to let go
Good Luck!
[SIGPIC][/SIGPIC]
SS/MA 2890
Anderson & Toren Comet
Joe Strunk is offline   Reply With Quote
Old 06-21-2024, 09:04 AM   #7
Ralph A Powell
Liked 225 Times in 136 Posts
On the original Ford Boss 302 blocks are all real good EXCEPT THE D0ZE-A it is not a Square Bore casting don?t try to over bore the 4.00 inch! Others will take a 4.060 bore!
Old 06-22-2024, 07:15 PM   #8
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
The early 302 blocks like 1968 are better sonic wise than the later blocks. Don't believe anything about the Mexican blocks other than. They have the hipo main caps. You can also just buy the steel main caps and install them. Definitely fill the block. Also neutral balance saves the block. Rule of thumb is 500hp and 8000 rpm is the limit on a std 2 bolt block. For the price of an original Boss 302 block you can buy a Dart
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 06-23-2024, 09:01 AM   #9
Ralph A Powell
Is the Dart legal! If so that?s what I would use!
Old 06-24-2024, 12:30 PM   #10
StockerStang912
StockerStang912's Avatar
Liked 21 Times in 7 Posts
Dart is legal, but if it's a Stocker I don't think an aftermarket block is worth the $$, work/effort to get accessories and headers to fit or the extra +30lbs. You'll be well under the 500hp and 8K RPM range which the early blocks are plenty good for.
Greg Viscome
193 GT/QA
StockerStang912 is offline   Reply With Quote
