Liked 241 Times in 80 Posts
I have a new stocker that has a brake pressure switch for launch control and I am trying to understand how it works and how to set it properly? I am just an old 2 step switch kind of guy (and am easily confused).
Any help is greatly appreciated! Text or call six03-78five-seven866 email: deanribeiro@comcast.net |
Liked 708 Times in 285 Posts
Look up Folk race cars. They have one worked really well. They are in Illinois last i heard.
Liked 1,361 Times in 416 Posts
here is one.Does it look close?
Paul H |
Liked 456 Times in 148 Posts
Folk Race cars closed. The switch you want has an adjustable pressure Range 100 to 1000 PSI. 3 wires. Black wire is not used.
Recommend wiring power to it thru a 3rd gear micro switch. Power is removed to the BPS when in 3rd gear ( if a 3sp Auto) This will allow you to apply brakes at 1,000 and the 2 step will not be activated. Set up a LED light in the circuit so you know when the 2 step is powered up with right brake PSI Believe they are 200.00 or so. Steve Teeter Stk/SS 620 |
#5 | |
Liked 57 Times in 24 Posts
The pressure switch is adjusted to close a set of electrical tips . When the brake pressure is reached voltage is pass to the 2 step device . Usually There is toggle switch to select between 2 step and 3 step for the water burn out |
#7 | |
Liked 4,389 Times in 505 Posts
![]() Last edited by Bobby Fazio; 07-17-2024 at 07:51 AM. |
#8 | |
Liked 133 Times in 76 Posts
Guest
Posts: n/a
I did that to my PP shifter Bobby, only activates in first gear. I mounted to the right side. I?ll take pics when I get home. Same brake switch too..
#10 | |
