Old 07-08-2024, 09:09 AM   #11
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: ppp shifter
Originally Posted by 1320racer View Post
This thread is about the PPP shifter not the Cheetah shifter that has performed flawlessly for 12 years I used it, never once did it not shift into 2nd gear with my turbo400, same cable as day 1 install and no maintenance ever done to the cable or the shifter. Just saying.
Ok I'll play. The first sentence on my thread. ( Same problem but on a Cheetah shifter). I mentioned as it had exact problem. The cables stiff and on the 1 2 shift the shifter would not hit the 2cd gear detent and the spring would push shifter over and miss the detent and continue into third. Lubed cable and that stopped it.
By the way this shifter was first install in 1993 and I bought it at a swap meet used. Second car in 2002. I would say your 12 year old shifter is brand new. Just saying.
Old 07-08-2024, 10:12 AM   #12
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Say what you want but my shifter made thousands of shifts unlike the shifter in a stocker
Old 07-08-2024, 11:30 AM   #13
Jeff Stout
You should know what your talking about before spoutng off. First SS 85 Monte Carlo. Second car Bracket raced 83 Monte Carlo. Stocker has a different Cheetah. shifter. Now can we get back on topic instead of seeing who has the best shifter and makes more passes. Mine didn't work right and I did what I did to fix it. Maybe offer some assistance instead of degrading PPP shifter or telling us you have the best damn shifter in the country and possibly the world. 1320 A Hat
Old 07-08-2024, 11:38 AM   #14
1320racer
1320racer's Avatar
I know what I'm talking about, you on the other hand are clueless! Jeff Stout A Hat extraordinaire
Old 07-08-2024, 12:29 PM   #15
Jeff Stout
Wow, from a guy that's all hat and no cattle and founder and president of Team Stupid you have put me in my place.
Old 07-08-2024, 12:43 PM   #16
1320racer
1320racer's Avatar
weak, just like your opinion here regarding the OP's freind's issue with a PPP shifter, NOT a Cheetah shifter to which he told you... WRONG, not the cable!
Talk about what you know, not what you think you know.
Old 07-08-2024, 12:50 PM   #17
Jeff Stout
No ***** Dick Tracy. It was a similar problem and just offered my opinion to help the guy. So far your help as help has been I would never have that shifter. That is great advice for someone asking for help. Sorry to the thread starter for getting off track. Hopefully you all found this to be humorous typing to prez of Team Stupid.
Old 07-08-2024, 02:43 PM   #18
FED 387
Liked 333 Times in 180 Posts
OK -- FOR A PPP SHIFTER ----FIRST YOU MUST adjust the shifter in SECOND GEAR---not First --Not third --Not reverse or park but SECOND gear ONLY----make sure that the shifter cable has no sharp bends in it-it is not binding it is securely mounted----on the gear selector/shifter arm on trans holes are ROUND not elongated, not oval etc. but PERFECTLY ROUND--the shifter arm is not flexing as you are shifting if it is beef it up so there is no flex---make sure that when you are adjusting the shifter arm on the trans that the shifter cable fitting slides into and out of the shifter arm on the trans WITH ABSOLUTELY no resistance ,drag, nothing and that the shifter arm is not moving as you do this --- even the slightest drag on sliding that fitting into the arm will cause problems or the arm moving as you are doing this procedure will cause problems --IT HAS TO BE PERFECT---Try it see what the results are---FED 387
Old 07-08-2024, 02:59 PM   #19
1320racer
1320racer's Avatar
yours was not a similar, your issue was with a Cheetah shifter NOT a PPP shifter.
Again, captain clueless, talk about what you know, not what you think you know!
Now back to this PPP shifter issue....
https://precisionperformance.com/wp-...structions.pdf
https://precisionperformance.com/wp-...ansmission.jpg
https://precisionperformance.com/wp-...ion-levers.jpg
If following the installation instructions in these 3 links doesn't resolve your friend's issue, then he needs to call PPP @ (208) 585-2814
Old 07-09-2024, 10:57 AM   #20
SBillinson
Liked 183 Times in 48 Posts
Originally Posted by jcw31 View Post
Have a friend with a ppp reverse pattern shifter . It has a problem going 1st to 3rd ,it seems if pushed forward hard it bypasses 2nd with what seems has no positive stop for it . Anybody else have this headache ?
I've got the forward (push) shift PPP for a C4 and the reverse (pull) for a Protrans 727/904. The forward shift doesn't have a positive stop for 2nd gear despite having a lip on the detent pattern. You may be able to adjust the spring in the handle or find some other way to make it a positive stop, but mine's an air shifter so I never really cared.
I found that if you just hit the lever with your palm or finger--like a slap stick shifter--it'll go right into 2nd gear and not skip to 3rd.
SS/BS 1921
SBillinson is offline   Reply With Quote
