Old 07-10-2024, 06:15 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default roll bar bending tools
Racers,
For those of you who bend your roll bars and other tubing, what tools are you using? I want something that will bend up to 1 5/8 mild steel tubing. Because it will be for occasional use, I think a manual bender is what I want.
Old 07-10-2024, 06:21 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
Default Re: roll bar bending tools
J D Squared Model 3. Does a nice, smooth job. Some of the bigger machines are not as handy.
US made. Quality piece.
Put hydraulics on it. Or you will wish you had.
Old 07-10-2024, 06:51 PM   #3
Woodfin
Thank you, sounds like a voice of experience about the power-assisted model.
Old 07-10-2024, 09:14 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
JD2 bender with BendTechEZ software. X2 on hydraulics ,I bent manually till I hit 70, ordered the hydraulics for it !
Old 07-10-2024, 10:20 PM   #5
mike britt
Liked 66 Times in 31 Posts
I use a bender from Affordable Bender.
mike britt is offline   Reply With Quote
Old 07-11-2024, 09:53 PM   #6
CMcAllister
Manual bending requires the machine to be substantially mounted, typically to the floor on a stand.
We went with hydraulics from the beginning. Electric motor, pump, reservoir, log splitter type valve, all mounted on a heavy cart on wheels that we fabricated, with the bender mounted at a good working height. 1.75" 4130 with ease.
Easily moved and used anywhere in the shop, even outside if need be. Easy to accommodate long lengths, wide sweeps, whatever and wherever we need, without making room or moving stuff around to do the job. Put it in a corner when not being used, rather than stuck in the middle of the floor.
Maybe a 2' x 2' footprint. Heavy enough that it is stable regardless what we have in it and it doesn't want to scoot around when using it.
Old 07-13-2024, 07:55 AM   #7
Jack Zimmerman
Liked 11 Times in 6 Posts
I also have a JD2 bender but they don't make a Model 3 anymore and the Model 32 is the replacement. But I'm cheap so I used an 8-ton, air over hydraulic jack ram from Harbor Freight to power it (~$120) and I built a roll around stand for the whole thing and it seems to work pretty well so far. If you're interested in that option there are lots of comments, pictures and videos on the internet for how to do it.
Jack Zimmerman is offline   Reply With Quote
Old 07-13-2024, 09:10 AM   #8
Woodfin
Thanks to all for the information. The deal is, that I am age 77 and most likely building my last roll cage system. Because the freight cost is so much, I considered buying a bender rather than purchasing a pre-bent kit.
After more pondering, the pre-bent kit, ordered through the wholesale side of Summit and picked up at the Arlington TX location is my best option.
In hindsight, about 20 years and 10 builds ago would have been the best time to buy a bender
