Old 07-16-2024, 08:21 AM   #11
Bobby Fazio
Bobby Fazio's Avatar
Default Re: Brake Question
Originally Posted by Henrys Toy View Post
Bob,
You might want to check with your brake caliper Manufacture and see if they have available a different "compound" brake pad material. There is usually different materials depending on the weight, and speed of the vehicle and temperatures your rotors see. Since its the starting line, you might need an aggressive material because the temps won't be very high. There is a company named EBC that make some really good quality pads for various performance uses. I would still check with your caliper Mfg. and explain your situation and see what they suggest. If you aren't satisfied after that then I would consult with someone like EBC and see if they can't help you. You might even need a "standard pad " for the fronts - so you can hold the car in the water with the line lock and an " aggressive " pad for the rears, to hold the car at an elevated RPM against the converter. I hope this helps, have a Good Day!
Respectfully,
Henry Kunz 1534 H/SA
Thanks Henry, I recently began running Aerospace DR97 pads front & rear, which are pretty aggressive. Aerospace uses them in the rear only and use a HP+ motorcross pad up front. Their master cylinder is a 60/40 front to rear according to their instructions and actually calls for 7:1 pedal ratio. Once I get more pressure I am debating taking the DR97 pad out of the front and going to the DTC30 pad up there to avoid locking up the fronts down at the finish line. Has anyone else run DR97 compound up front?
'65 Mustang SS/L & L/SA
Old 07-16-2024, 09:31 AM   #12
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Aerospace brakes/components are way down on the list of drag car brakes. There is a difference.
Old 07-16-2024, 01:03 PM   #13
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I have them on my car. The have been flawless. When installed correctly they have very little drag. Good stopping power. I have a trans brake so don?t try to hold the car on the line. Very precise for staging. There probably is Better out there but for the price they are a good value
Mike Pearson 2485 SS
Old 07-16-2024, 01:15 PM   #14
1320racer
1320racer's Avatar
Many that have tried them that now have Mark Williams or Strange brakes would disagree
Old 07-16-2024, 02:41 PM   #15
jimmyparker
Liked 309 Times in 88 Posts
When aerospace first got in to the brake business i had quite a few problems with them, sticky calipers, etc. but in the last 10-12 years i've had zero problems with them.
jimmyparker is offline   Reply With Quote
Old 07-16-2024, 04:32 PM   #16
Mike Pearson
I hear a lot of people complaining about Strange brakes dragging. Never hear anything bad about MW stuff
Old 07-16-2024, 08:08 PM   #17
Frank Castros
In case I missed it, the consensus on Lamb Components brake systems?
Old 07-16-2024, 08:57 PM   #18
L.Fite
Liked 497 Times in 243 Posts
I've used Lamb on everything I've had since the 80's
Everything else drivetrain related is MW.
MW would be my second choice for brakes.
Both are quality pieces...
Can't speak for anyone else...
L.Fite is offline   Reply With Quote
Old 07-17-2024, 04:38 AM   #19
BZenzen
BZenzen's Avatar
Liked 472 Times in 82 Posts
We run Lamb brakes on our SS car, came on the car when we purchased it back in 07. No issues, little to no drag at all, we run a trans brake so can't speak on the starting line hold, but they've been great overall.
Brian Zenzen
SS 5404
STK 5401
BZenzen is offline   Reply With Quote
Old 07-17-2024, 11:12 AM   #20
340Cuda
Liked 805 Times in 341 Posts
I have a friend who switched from another brand to Lamb brakes on his Super Stock car.
What I immediately noticed is that the front wheels kept turning during the wheelstands with the Lamb brakes.
