Old 07-30-2024, 11:38 PM   #11
littlemanjoe
Liked 75 Times in 28 Posts
Default Re: Header building
Originally Posted by monte385 View Post
I mentioned it to him, he is waiting on parts for his car so he hasn't raced all summer.
Thank you!
Hopefully he has his car ready for St Louis. I've been in those shoes and they suck.
Thanks,
Mik
littlemanjoe is offline   Reply With Quote
Old 07-31-2024, 09:27 AM   #12
rebelrouser
Liked 8 Times in 3 Posts
Originally Posted by littlemanjoe View Post
How critical is it, for the tubes to be the same length when building headers?
Are there important dos and don'ts when building them?
Header builders seem to be a dying breed around Ohio, so we may have to try it ourselves.
Thanks,
Mike
3020 A/SA
I build my own headers; I use a program called pipemax to design them for size and length. the program also can be used to build step headers. To answer your question when building a set to fit in an engine compartment and maintain equal length is pretty hard. Getting access for plugs and starter is just as important. On a dyno not sure what the loss would be on different lengths, but I seldom see any factory-built headers that are even close. I am a big believer in step headers and have seen gains on the dyno.
rebelrouser is offline   Reply With Quote
Old 08-02-2024, 01:34 PM   #13
Dirk Olson
Liked 172 Times in 46 Posts
Ben Line did my Headers and he did a fantastic job! They fit awesome, tucked up tight, out of the way for easy transmission, clutch removal, O2's are easy to get at and in the correct location and they Work! Give Him a call.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 08-02-2024, 07:19 PM   #14
Frank Castros
Kromer Kraft Headers
Old 08-03-2024, 06:58 AM   #15
whompin_wedge
Liked 103 Times in 25 Posts
Call Mike Schaefer at The Mod Shop - Lakeview, OH
He builds some awesome headers. He built the headers on Doug Duell's stocker and his SS challenger for reference.
937-935-9898
He has done a lot of work for me in the past. Great guy to work with.
Casey FJ
whompin_wedge is offline   Reply With Quote
Old 08-03-2024, 08:04 AM   #16
Rick J
Liked 73 Times in 37 Posts
Does equal length mean equal flow and pulse timing?
Seen a championship Pro Stock with unequal length primaries
Rick J is offline   Reply With Quote
Old 08-03-2024, 08:10 AM   #17
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
equal length in our cars, cars with the firewall in the stock location, stock frame rails, etc. means sacrificing fit, ease of installation, spark plug access, ground clearance and in some cars, having to remove and or cutting the inner fender wells all for nothing on the time slip.
Old 08-03-2024, 11:29 AM   #18
SpeierRacing
Liked 70 Times in 23 Posts
I just went through this in my Cavalier. I ended up with equal length and in firing order. There was no way I could get the length I thought it needed with the tight space. So I had him put the proper collector length collector and connect the flange.
I will say this. Equal length tubes with a LS firing order (SBC), makes a crazy looking header. Have pics if interested.
SpeierRacing is offline   Reply With Quote
Old 08-03-2024, 11:54 AM   #19
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Chad, do you and any pics of the final units you are willing to share? I am not following the firing order comment you made. Thanks
Andy Friar
Andy Friar is offline   Reply With Quote
Old 08-03-2024, 12:12 PM   #20
SpeierRacing
