View Poll Results: Should roller rockers be allowed on all stockers?
Yes 113 53.81%
No 97 46.19%
Voters: 210. You may not vote on this poll
Old 05-23-2008, 12:08 PM   #1
Patrick Kelliher
Question Roller Rockers in Stock
Some have suggested that roller rockers be allowed on all cars in stock to reduce breakage.
Patrick Kelliher is offline   Reply With Quote
Old 05-23-2008, 03:57 PM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Roller Rockers in Stock
Let's just move to Super Stock and get it over with.
Or better yet, go race IHRA. Nothing against IHRA, but the rule is already there.
Stop changing the rules (or trying to change the rules)!
Bill Grubbs is offline   Reply With Quote
Old 05-23-2008, 04:42 PM   #3
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Bill
I am with you 100% , but what I think is the bigger picture is the eventual combining of classes into a new super stock . It's a shame we either keep our cars the way they are right now or we will all suffer the consequences.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 05-23-2008, 05:45 PM   #4
Mark Callanan
Liked 64 Times in 14 Posts
Well said Bill
If you keep changing it there will be no more stock(I am sure some feel there isnt now....)
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 05-23-2008, 08:38 PM   #5
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
I made the change and ran the roller deal and it made no difference what so ever. I think it might have fell off Stamped steel forever!!
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 05-23-2008, 09:36 PM   #6
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Roller Rockers in Stock
I know the stock stamped steel rockers are what is legal in stock and I also realize that the more after market parts allowed, the closer stock gets to super stock. However, when considering the cost of an engine due to rocker arm failure, for that reason I am for changing the rules and allowing after market rocker arms. I also know stock rocker arms will perform as well as after market. The only reason I would consider changing to after market rocker arms is they are much stronger and they last for years.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 05-24-2008, 02:03 AM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: Roller Rockers in Stock
I'll add a little more (don't kill me). Not everyone runs a small block chevy...that being said rockers are or can be very hard to find. My 230 I6 the only way I could get rocker arms for it was go to NAPA I could get a box with a rocker piviot ball & nut. I would have to order about 3 dozen to get a set that was close...even then I had the cam grinder grind in extra lift to get it close to what was legal! Of course they make roller rockers for the inline.
Old 05-24-2008, 03:12 AM   #8
Jeff Lee
Jeff Lee's Avatar
I have a bucket of NOS AMC rockers. Once I found a source, I bought everything the guy had. I found the aftermarket rockers (standard replacement, Sealed Power, TRW, etc.) we're not built with the same rockwell hardness as per OEM and as a result, they would pull the cup out of the base (were the rocker ball sits. AMC rocker is virtuall identical in appearance to SBC, just longer) almost immediately. Cryogenic treatment did not help. Neither did heat treatments and coatings. The NOS units faired much better and didn't require prep work. Ever hear the phrase "old iron is better than old iron"?
And I've talked to plenty of racer's on this subject. It's a problem with BBC, Fords of all sizes, AMC, GM...basically anything that uses a stamped rocker that rides on a stud. As I said on the other post regarding this subject, there are cure's for some makes. But you might spend 3x the cost of a set of Crane Gold roller rockers.
What's really intersting to me is the lack of responses to the post I made regarding "killer" valve-train parts and costs elsewhere on this forum.
Jeff Lee 7494 D/S '70 AMX
Old 05-24-2008, 08:07 AM   #9
Liked 1,892 Times in 423 Posts
We're not killing rockers. We broke a stud before we put the Holroyd stuff on but no rockers. We've got over 2 years on these. Yes, we run killer springs. We might break a rocker today, but we haven't yet. But yes, the stud caused catastrophic damage, we lost a whole engine.
Old 05-24-2008, 09:00 PM   #10
stock eliminator
I know a lot of people against roller rockers but why not use the hydraulic roller rockers from Comp. Cams and not the mech. roller rockers. I think the way prices are for building these motors and gas to get to the track we should all vote for reliablity keeping things together and not worry about stock class cars are knocking on the door of super stock! my 2 cents! also we should allow larger studs because of spring pressures. And another thing if you want to run pure stock they have it in IHRA. Not trying to start trouble just my say.
stock eliminator is offline   Reply With Quote
