Liked 9 Times in 5 Posts
Hi All. I want to jump in with you guys into Super Stock with a slightly oddball combination that does not have a steel crankshaft. This is a small V8 so will spin reasonably fast. I possibly could destroke a longer stroke steel shaft, but it would be quite a bit of effort.
Just looking for similar ish experience, which clearly is not directly comparable. Do the 289 Ford guys use a cast crank and does it hold up? Other combinations? |
#2 | |
Liked 34 Times in 21 Posts
Liked 880 Times in 311 Posts
Built quite a few 680 -720 HP Bracket race BBC with cast cranks 2.200 rods. Turned a few to 2.100 rod journal for SS. The 2.100 eventually cracked.
Adger Smith (Former SS) |
Liked 783 Times in 195 Posts
Ken, If I am correct in my assumption about the combination you are talking about, you could find an ArmaSteel shaft which would be somewhat better. But in any case, the cast crank will be more than adequate and will survive the 8000+ operation range you are anticipating.
Liked 734 Times in 385 Posts
I see in the Indy thread that 2 of the 4 stockers in the barn are Pontiac. Does anyone know if they are running a cast crank?
Stan |
Liked 239 Times in 114 Posts
I ran my 455 SD Pontiac in Super Stock, and it has always had a Cast crank/ The rules for SS allow you to run an accepted aftermarket crankshaft, so that may also be a option.
Thanks guys. I'd already started down the road with a stock cast crank, but just started to second guess myself. Time to keep going. Dwight has assumed right on the combo, and unfortunately there is minimal aftermarket support, and no cranks are available.
Liked 132 Times in 30 Posts
Give Jim Harrison a shout at Fast-Shaft...(618) 445-2556
Gary Smith "another broke racer spectating" |
Liked 72 Times in 27 Posts
