Old 09-07-2024, 07:54 PM   #1
1700camaro
Liked 226 Times in 115 Posts
Default Wheel Spacers
I was mocking up our new double beadlock wheels today. I ran into an issue of the rebound adjuster knob hitting the beadlock bolt heads. These are AFCO double adjustable shocks mounted in the factory locations. I have clearance if I remove the knob but wish to have it on.
I'm debating on using Baer Brakes wheel spacers .250 thick. I'm not big on using spacers. Plus, I'm running 5/8" studs & would have to drill the stud holes to the proper dia.
Anybody have any ideas or different solutions to this issue?
1700camaro is offline   Reply With Quote
Old 09-07-2024, 11:22 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Default Re: Wheel Spacers
Billet spacers, plenty of them at Summit.
Mike 7570 A/SA
Old 09-08-2024, 12:01 AM   #3
1700camaro
The Baer Brakes spacers were billet also.
Below is what Billet Specialties states about their spacer.
"Installation may require longer wheel studs. Fits wheel sizes 15 x 3.5 through 15 x10 in. Not for use with 5/8 in. race-type studs."
Old 09-08-2024, 02:01 AM   #4
james schaechter
We make them at TBM
https://tbmbrakes.com/products/1-4-t...-8-stud-by-tbm
James Schaechter 3163 STK
Old 09-08-2024, 09:06 AM   #5
1700camaro
Originally Posted by james schaechter View Post
Thank-You!
Old 09-09-2024, 07:55 AM   #6
curtis reed
Liked 125 Times in 59 Posts
Can't you run those shocks upside down? Would that give you the clearance you need?
curtis reed is offline   Reply With Quote
Old 09-09-2024, 09:35 AM   #7
1700camaro
The shocks are mounted in the original factory locations. The link shows the shocks I'm using & the configuration.
https://proshop.summitracing.com/parts/afc-3870r-2
Old 09-09-2024, 05:26 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
The shocks in that link you provided are front shocks for a gen one Camaro
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 09-09-2024, 06:59 PM   #9
1700camaro
The shocks in the link have been mounted on the rear for many years. The AFCO catalog list them for the rear on 1970-1981 Camaro, our car is a 1980. I called them 1st before ordering. I also checked our shock boxes & they have that part # also.
Page 22 has the listing for applications in the link.
https://www.afcoracing.com/Userfiles...ag-low-res.pdf
Old 09-13-2024, 07:40 PM   #10
1700camaro
We received the TBM wheel spacers today, 2 pairs. My mistake when I placed the order!
I might return the other set & get a pair of .125 thick. I have to take some measurements to see if the thinner ones will work.
The spacers solve the problem of the shock adjustment shaft hitting on the beadlock ring bolt heads. I still don't have the room to run the adjuster knob on the shafts.
