Old 09-13-2024, 12:14 PM   #1
Superpro
Liked 105 Times in 38 Posts
Default Bracket mode?
As the title says, what does a racer selling a stocker refer to when he mentions "Bracket Mode". Thanks in advance
Superpro is offline   Reply With Quote
Old 09-13-2024, 12:18 PM   #2
Bobby Lundholm
Liked 127 Times in 49 Posts
Default Re: Bracket mode?
That it's not on kill and should have more left in it.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 09-13-2024, 02:24 PM   #3
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 226 Times in 97 Posts
In the mode that it is normally raced.
Typical fluid levels and viscosity, regular water temperature, starting line RPM, etc.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 09-13-2024, 02:34 PM   #4
MR DERBY CITY
Liked 8,127 Times in 1,534 Posts
and weight in the trunk. …...
Old 09-13-2024, 03:58 PM   #5
Oscarf164
Liked 5 Times in 4 Posts
Ok, what's "on kill" then?
Oscarf164 is offline   Reply With Quote
Old 09-13-2024, 04:00 PM   #6
Superpro
Thanks guys!
Old 09-13-2024, 06:00 PM   #7
HR9121
HR9121's Avatar
Minimum weight, minimum amount of oil in the pan, air pressure as high as possible in the tires and as cold as you get the water temperature and Jim Marshall would never do this but ice down the intake.
James Williamson
W200 J/SA. SS/JA
Old 09-13-2024, 06:36 PM   #8
Tom Broome
Liked 88 Times in 43 Posts
Couldn't resist.
That's where you put in less, lighter oil, chill the engine, adjust the starting RPM line up, maybe some timing.
Remove any extra ballast.....
And the car picks up less than just removing the weight would...
Tom Broome is offline   Reply With Quote
