Old 09-16-2024, 08:36 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Default sbc rear intake manifold oil leaks
whats the best to seal the intake ? I've been using red silicone for years , but the last two engines have leaked badly , I Even redid it and it still leaked, is the red silicone no good ?
Mike Savelle is offline   Reply With Quote
Old 09-16-2024, 09:58 AM   #2
JP1738
JP1738's Avatar
Liked 1,237 Times in 351 Posts
Default Re: sbc rear intake manifold oil leaks
I was having this issue on my super gas sbc. I used black gasket maker (Permatex) and smeared it liberally across the back of the china wall after a thorough cleaning. Hasn't leaked since.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 09-16-2024, 10:00 AM   #3
JP1738
JP1738's Avatar
Well at least it doesn't leak out of the back of the manifold anymore. The engine leaks like a sieve, just not from there lol.
Dawson Pauley
Old 09-16-2024, 10:28 AM   #4
cad
cad's Avatar
Liked 93 Times in 52 Posts
Ford TA-31 RTV silicone. Ive used it for years.
https://www.amazon.com/Genuine-Ford-TA-31-Silicone-Sealant
Old 09-16-2024, 11:05 AM   #5
Mark Ugrich
Liked 71 Times in 38 Posts
G.M. 10-2006 engine sealant is good stuff also.
Old 09-16-2024, 11:50 AM   #6
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: sbc rear intake manifold oil leaks
Good morning to all,
I've been using the Permatex " Right Stuff " for a couple of years now.
The engine in my Suburban I recently went over the valve adjustment and found a couple of wet area's on the valve cover gaskets - I cleaned and used the Right Stuff on them and that oil leak is solved. No more oil smell while sitting in traffic. I use that on all my small block and big block china walls - zero leaks. It dries quick enough while dyno testing as well. I also use the Permatex Grey silicone with great success as long as you have time for it to properly cure. Make sure the surfaces are CLEAN and OIL FREE.
I found that to be very important in the curing process.
I hope that helps.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 09-16-2024, 02:04 PM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Permatex Right Stuff!. I’ve never had an intake manifold, water pump, water neck leak on any engine using this stuff for decades and I’m convinced you could lift the engine from the intake manifold without any bolts in it.
Old 09-16-2024, 04:00 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
permatex ultra gray here. Make sure its not the oil gauge fitting back there. There is no pressure on the back of the intake. Never had a leak there.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 09-17-2024, 07:22 AM   #9
Mike Savelle
thanks for the ideas , will take it apart and give it a try ,
Old 09-17-2024, 08:02 AM   #10
pmrphil
Liked 348 Times in 152 Posts
Yup, use the Permatex "Right Stuff" and install the manifold with it wet, don't let it "skin" over. It won't leak.
Phil Molski
PMR Performance
S/C 1623
