Old 09-20-2024, 09:19 PM   #11
Woodfin
Liked 288 Times in 109 Posts
Default Re: Suspesion setup with radial slicks "help"
In my experience, and as Ed said, because of the front weight, OE-type springs would be better. Landrum has a wide selection of drag-front sprigs to fit the factory location. The front needs as much travel as possible, and the static front height should be slightly lower than stock. One no-cost mod is to relocate the front upper ball joints to a new location, on the bottom of the control arm, not the top. Doing this will at 1/2" + to the front travel. Also, the front system should be free and move smoothly.
Old 09-20-2024, 09:29 PM   #12
M120
Liked 22 Times in 12 Posts
I agree that more travel will help you.
My Chevelle has 6+" of travel with stock suspension in the front. Stock type coils and shocks.
Get as much travel and control it with a quality shock.
Tubular A arms look cool but not needed in my opinion. They actually sometimes weigh more!
For the rear, pick your poison. It depends on SLR, slicks,...
I actually had good luck with traction action bars til they bent all the factory mounts.
Have fun and good luck
Mark Mueller
FLC
M120 is offline   Reply With Quote
Old 09-21-2024, 06:59 AM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Woodfin...KNOWS!
Old 09-21-2024, 11:35 AM   #14
DG
DG's Avatar
Liked 469 Times in 99 Posts
Tire pressure gauges go bad. Check your gauge against others to verify its accuracy. Not saying thats your problem, but its an easy fix if it is your problem. I recently found out mine was 6 lbs off causing lots of traction problems since the beginning of the year.
DG is offline   Reply With Quote
Old 09-21-2024, 01:11 PM   #15
1320racer
1320racer's Avatar
If you find a tire gauge that matches yours, it’s luck! Tire gauge readings vary greatly especially that most are Chinese junk! There is no wrong gauge, all that matters is what your gauge reads. Never borrow someone’s gauge to set your pressure.
Old 09-24-2024, 09:54 AM   #16
cad
cad's Avatar
Liked 93 Times in 52 Posts
The launch in the video above looks pretty darn good. Not sure where you get the 165% antisquat number... If you are watching "Kevins youtube videos on antisquat", they are only good for one thing...entertainment. I watched your video multiple times in slomo and it isnt hitting the tire extremely hard. Alot of variability comes in track temp/track prep, as well as the age of your tires. Replace the front springs as mentioned and put a good dbl adj front shock on it. IMO, you'll find as much hook controlling the front as messing with a stock 4 bar rear setup. Some people will say pinion angle doesnt matter..... however, very few have stated what they have. .
