Old 09-22-2024, 08:34 PM   #1
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Default Fuel Check & Scales
I'm going to my first Division race at Bakerfield in a week and a half for the double race. I have a few break in runs on the car from some ANRA events.
I raced Super Street and Super Gas from the mid 80's to 2000 and I've had to weigh once a race in those classes but I don't remember how accurate their scale is and I'm new to fuel check.
Do you bring your own cup or do they have some for fuel check?
How much extra weight do you bring to adjust for different scales? (right now I only have about 10lb extra)
I printed my tech card but I can't get the website to accept payment, luckily they have pay at the gate available.
Thanks.
Mike 7570 A/SA
Old 09-22-2024, 08:45 PM   #2
DG
DG's Avatar
Liked 469 Times in 99 Posts
Default Re: Fuel Check & Scales
Hi Mike,
Welcome to stock division 7 racing. They will provide the cup for fuel check. As far as scale variances, I never need more than 30 pounds to make up diferences in scales from track to track. However, you really need to know what your car weighs. If your 50 lbs lite for your class, your going to need to drop down a class or add +/- 70 lbs to get in the desired class.
Good Luck,
Darin Grossi
DG is offline   Reply With Quote
Old 09-22-2024, 08:49 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
At Bakersfield their scales are the old balance beam. I think every other track has electronic scales. They set it to your min weight and if it moves you’re fine. Just about every S/SS racer carries extra weight with them so I’m sure they will lend you some if needed. As for fuel check they supply a cup. Just make sure you have a way of getting your fuel under the hood.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 09-22-2024, 11:54 PM   #4
Mike Gray
Mike Gray's Avatar
Thanks guys, for the info on weight and fuel check. My adjustable weight for the weight box is in 5lb mesh bags. I only have 5 right now and need all of them to make the minimum. I got a little carried away building a light car and already added big weight bars in the trunk. I'll try to get some more 5lb bags ready before the Bakersfield race.
Mike 7570 A/SA
Old 09-23-2024, 04:49 AM   #5
GTX JOHN
We will be at the race and will have extra weight
in the trailer.
It is not unusual for that track to have scale problems.
You are already at the minimum weight for the lightest
class your car is legal to run?
John Irving
741 Stock
741 Super Stock
Old 09-23-2024, 11:51 AM   #6
Mike Gray
Mike Gray's Avatar
in the trailer.
John, I could make the minimum for AA which would be the lightest class. When I started building the car I was looking at B or C. A few changes in the engine build and it became a natural A car but it’s not 9 second legal right now. To make B takes a whole lot more weight so A it is.
Mike 7570 A/SA
Old 09-23-2024, 04:34 PM   #7
Kirk Morgan
Liked 81 Times in 45 Posts
The tech people may not be happy with mesh bags. All weight has to be properly secured. The weight box can be a 100 lbs or less including the box.
Kirk Morgan is offline   Reply With Quote
Old 09-23-2024, 04:55 PM   #8
Mike Gray
Mike Gray's Avatar
They are in the enclosed weight box. -
"Weight boxes (two maximum) made of
1/8-inch material may be constructed to hold small items such
as shot bags, lead bars, etc., as long as box and contents
do not weigh more than 100 pounds or as outlined in Class
Requirements. The box must be securely fastened to the frame
or crossmember with at least two 1/2-inch-diameter steel bolts"
Mike 7570 A/SA
Old 09-23-2024, 09:55 PM   #9
Kirk Morgan
Did not know how much or where you were putting the weight just hoping you have a smooth experience. Iam fully aware of the rules.
Old 09-27-2024, 02:34 PM   #10
Jim Stone
Actually you can only have 50lbs max in two separate weight boxes totaling 100lbs in the stock class. See below:
BALLAST
Weight box permitted. Only 100 pounds removable ballast permitted, including box (two-box maximum with 50 pounds each).Must be attached to frame or crossmember with minimum of two 1 /2-inch bolts. May not be attached to roll bar or cage. Additional ballast must be permanently attached to frame or crossmember, i.e., bolted with at least two 1/2-inch bolts per 100 pounds, with nut welded to bolt. See WEIGHT. See General Regulations 4:2.
Jim Stone is offline   Reply With Quote
