Old 10-06-2024, 12:19 PM   #1
Bob F
Liked 16 Times in 11 Posts
Default Rear gear question
3400#
440”. 1.80 1st gear 4.10 rear 28? tire.
Car isn”t performing to expectations.
Only running low tens @ 133. 1.45 60?
Think it needs a lower gear?
Bob F is offline   Reply With Quote
Old 10-06-2024, 12:39 PM   #2
Billy Nees
Default Re: Rear gear question
Well, that would depend on your finish-line RPM. Just looking at your dyno numbers and not knowing much else, I would probably gear it to hit the FL at 7000/7200. But that's a Stocker guy talking. That would to me be conservative. Not knowing what's in your stuff.
Billy Nees 1188 STK, SS
Old 10-06-2024, 01:01 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Can’t read the graph. At what RPM, does it make peak HP and peak torque. What does your converter flash to and fall back on the gear change and what RPM are you shifting at?
Old 10-06-2024, 01:04 PM   #4
Billy Nees
Peak HP, 6700
Peak TQ, 5300
1.80 1st, it's gotta be a PG.
Old 10-06-2024, 01:12 PM   #5
1320racer
1320racer's Avatar
For optimum ET, If it was mine, it would have a converter that flashes to 5800, I’d be shifting at 7200 and gear it so it’s crossing the stripe at 7700. I would also get a 30” tire under it if you can not go wider.
Old 10-06-2024, 02:54 PM   #6
Bob F
It?s 7100 at the finish line now.
Convertor is around 5800 I believe.
Old 10-06-2024, 03:03 PM   #7
1320racer
1320racer's Avatar
If you don’t have a data recorder get one or at least a playback tach so you have real data. That said, definitely needs more gear
Old 10-06-2024, 04:41 PM   #8
Billy Nees
And more tire.
Old 10-06-2024, 05:30 PM   #9
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Rarely does more gear hurt! Depends on what your wallet can stand.
Old 10-06-2024, 05:46 PM   #10
1320racer
1320racer's Avatar
And more tire.
As I stated in post #5
