#41 |
Liked 10,837 Times in 2,252 Posts
Race 3-6 #129 won over #6 in E1
#42 | |
Liked 359 Times in 103 Posts
This is going to stop many of the Division racers on the west and north side of the largest geographical Division to skip a double due to the travel time and miles. Just My 2 Cents Rick Cates Canyon TX |
#43 | |
Liked 396 Times in 208 Posts
So, it will end up with inconsistent decisions and neither D.D.'s nor racers need that at all. It is a simple fix as I stated in my novel earlier and back in April. You simply no longer get a Full stage and Starter Go as described in the Q rules when Starter checks track for clear (flips switch to activate tree), and then Drivers control the stage timers. It is now a reality of Starter Go, then staging with no assurance that both cars will fully stage (a failure of either to do so results in a red light DQ a N.T. but surely a qualifying attempt was made. An incomplete pass is the result and simply should receive the 28 second Q pass result. Then none of the rules are in conflict. The entry monies are applied to NHRA purses/expenses, the racer has the ensuing time to fix their entry, and the show goes on. Failure to appear the next round to the lane call the laddered opponent earns the comp bye. Fixing what we know is broke is just smart. Not getting it fixed is just repeated frustration watching it happen repeatedly, and knowing it is leading to stress for all it happens to.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#44 |
Liked 56 Times in 10 Posts
In Tulsa a couple weeks ago Roger Brogdon was allowed to be pushed out of the burnout box, fix the problem and make a qualifying run that counted in comp. Guess it matters who the DD and the racer are!
