Old 10-08-2024, 09:42 AM   #21
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Default Re: Rear gear question
Originally Posted by 1320racer View Post
SLR is internet forum bs like dynamic compression ratio.
My SLR is 8.748, what am I doing wrong?
Maybe if you really understood dynamic compression ratio, I would take you seriously!
Without knowing anything about your car. How would anyone know what you might need for a SLR?
I will need even touch this.
Stan
Old 10-08-2024, 09:53 AM   #22
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
keep spewing your misinformation and myth Stan no one with a clue takes you seriously
Old 10-08-2024, 10:33 AM   #23
goinbroke2
Liked 405 Times in 158 Posts
I laughed so hard at this I almost spit my tea out!!!! LOL!!! Yeah, Stan doesn't know anything about cars/engines/head flow/LOL!!!!!
Jim Miller
103 U/SA
Old 10-08-2024, 11:00 AM   #24
1320racer
1320racer's Avatar
Clearly not but you think he does, no surprise.
Old 10-08-2024, 11:33 AM   #25
Stan Weiss
Stan Weiss's Avatar
Lets look at Dynamic Compression Ratio a little closer. It is based on engine parameters and IVC. So unless you have done something to have these change once the engine is running it is really now static. People look at Cranking Compression PSI and running cylinder pressure and say see see the DCR has changed. No what has changed is the engines VE / mass air flow. There have been OEM manufactures that actually call this trapped CR and listed it as an engine spec.
Stan
Old 10-08-2024, 12:32 PM   #26
1320racer
1320racer's Avatar
Let’s not! Start another thread about meaningless DCR. Meanwhile this thread is about rear gear, more of which the OP needs.
Old 10-08-2024, 12:50 PM   #27
Stan Weiss
Stan Weiss's Avatar
Let?s not! Start another thread about meaningless DCR. Meanwhile this thread is about rear gear, more of which the OP needs.
So peak HP is @ 6700 RPM and he said he is crossing the strip @ 7100 RPM. So just how much rear gear would you like him to run?
As I, and other have said he needs a 3 speed trans.
Stan
Old 10-08-2024, 01:16 PM   #28
Bob F
Liked 16 Times in 11 Posts
800 rpm fallback.
Mast m311 Cyl head 273 runner
Bob F is offline   Reply With Quote
Old 10-08-2024, 01:56 PM   #29
1320racer
1320racer's Avatar
He does not NEED a 3 speed trans, he NEEDS more gear!
Originally Posted by Bob F View Post
800 rpm fallback.
from what RPM/shift point?
Old 10-08-2024, 03:15 PM   #30
Bob F
7000
