Old 10-09-2024, 10:47 AM   #1
FLEMING
Liked 56 Times in 26 Posts
Default lightweight battery recommendation (non lipo/life)
Looking for a lighter battery option but not interested in lipo/life type.. Any recomendations?
FLEMING is offline   Reply With Quote
Old 10-09-2024, 10:51 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: lightweight battery recommendation (non lipo/life)
not worth the $ nor effort, nothing to be gained on the time slip.
Old 10-09-2024, 11:02 AM   #3
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Exclamation Re: lightweight battery recommendation (non lipo/life)
Wow.
I bought a battery that was almost 30 pounds lighter.Amazingly,the car picked up almost .03.
Old 10-09-2024, 11:04 AM   #4
FLEMING
Not really worried about et gain.. I just know adding 40lbs on the front of my car effected how my car works.. (still works good) just taking that 40 from rear and putting it up front was the effect I was trying to overcome.. and no I dont want to just add more weight to the rear to make the balance what it was before
Old 10-09-2024, 11:37 AM   #5
1320racer
1320racer's Avatar
Originally Posted by 442OLDS View Post
Wow.
been there done that and gained NOTHING in 2 cars.
Old 10-09-2024, 04:51 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 2,022 Times in 607 Posts
Go Lithium has some nice lightweight batteries. 8 lbs. if your car is at it?s minimum weight already and has a good consistent 60 Ft times then changing batteries might no net and improvements in the ET. If you need to get 30 lbs off of the scale weight then it will be a good way to loose the weight. And probably pick up .02-.03
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 10-09-2024, 04:58 PM   #7
1320racer
1320racer's Avatar
The OP said…
Old 10-10-2024, 10:48 AM   #8
cad
cad's Avatar
Liked 93 Times in 52 Posts
I ran an Odyssey PC925 for several years in my 68 Camaro, and it cranked a 13:1 SBC with no issue.
27 lbs. 900 Cranking Amps for 5 Seconds
Old 10-10-2024, 11:06 AM   #9
james schaechter
Liked 1,452 Times in 303 Posts
Assuming this isn’t a bracket car like 1320 and has limitations, lighter batteries and other legal weight conscious decisions can help. Especially if track conditions are not ideal.
We used to run a light weight 12 volt Braille battery and it was less than 10 lbs. we didn?t use it for eliminator, but it was part of our prep for Indy and class runs. It worked well and was a standard AGM.
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 10-10-2024, 01:09 PM   #10
Steve Grady
Steve Grady's Avatar
Liked 187 Times in 60 Posts
Total Power has both Lithium 16 volt batteries and lightweight 12 volt AGM batteries and are a Contingency sponsor as well as made in the USA.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
