Liked 55 Times in 26 Posts
Looking for a lighter battery option but not interested in lipo/life type.. Any recomendations?
Liked 759 Times in 379 Posts
not worth the $ nor effort, nothing to be gained on the time slip.
Liked 282 Times in 103 Posts
Not really worried about et gain.. I just know adding 40lbs on the front of my car effected how my car works.. (still works good) just taking that 40 from rear and putting it up front was the effect I was trying to overcome.. and no I dont want to just add more weight to the rear to make the balance what it was before
Liked 1,943 Times in 584 Posts
Go Lithium has some nice lightweight batteries. 8 lbs. if your car is at it?s minimum weight already and has a good consistent 60 Ft times then changing batteries might no net and improvements in the ET. If you need to get 30 lbs off of the scale weight then it will be a good way to loose the weight. And probably pick up .02-.03
Mike Pearson 2485 SS |
Liked 93 Times in 52 Posts
I ran an Odyssey PC925 for several years in my 68 Camaro, and it cranked a 13:1 SBC with no issue.
27 lbs. 900 Cranking Amps for 5 Seconds |
#9 | |
Liked 1,436 Times in 299 Posts
We used to run a light weight 12 volt Braille battery and it was less than 10 lbs. we didn?t use it for eliminator, but it was part of our prep for Indy and class runs. It worked well and was a standard AGM.
James Schaechter 3163 STK |
Liked 131 Times in 43 Posts
Total Power has both Lithium 16 volt batteries and lightweight 12 volt AGM batteries and are a Contingency sponsor as well as made in the USA.
Div 3 Sales, Service and Tech for many manufacturers |
