Old 10-10-2024, 01:28 PM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: lightweight battery recommendation (non lipo/life)
I ran Total Power’s small 12volt battery which is an aircraft battery made by Concorde and its junk as longevity is concerned.
Old 10-10-2024, 01:38 PM   #12
Billy Nees
Every car that I've raced for the last 30+ years (except the FWD stuff) has had a Deka 850/1000 CCA battery. They're made in Pa. they last a long time and they'll start almost anything. I can live with the weight penalty.
Billy Nees 1188 STK, SS
Old 10-10-2024, 02:47 PM   #13
1320racer
1320racer's Avatar
Before switching to 16volts in 2022, I ran AC Delco batteries in my door cars for 30 years, same spec as Billy’s Deka and I never had a bad one, failure or missed round due to a slow cranking or dead battery.
The fact is the small, lightweight 12volt batteries just do not have the cranking amps that the full size batteries do nor do the last as long.
Old 10-11-2024, 07:17 AM   #14
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I've been running the 11 lb Braille batteries for about 10 years now and they've been great. I do have two, one in stock location and one in the trunk. Not sure I'd trust just one at only 360 cranking amps, but they have a 21 pounder with 550.
I've left the fan and water pump on for a couple hours (twice in one weekend lol) dragging them down to 20-30% and they charge right back up. The ones in the car now are from 2020 so I'll replace over the winter.
Paul Merolla is offline   Reply With Quote
Old 10-11-2024, 01:40 PM   #15
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Had a 17 pound braille in the nova, even fully charged up it would struggle. So I can see where 2 11lbs plus a alternator would be about as low as you could safely go with AGM. I swapped out the Braille for a 12V Lithium(with BMS) and it likes it 100% more, and dropped over 11 pounds, but its a lithium so not for everyone.
Eric Merryfield 1883 STK
Old 10-11-2024, 03:15 PM   #16
Jeff Stout
Liked 706 Times in 283 Posts
In my bracket car I ran 1 optima and 1 motorcycle battery (11lb) with alternator. Didn't know if it would work. 2 seasons later motorcycle battery gave up.
But be a stocker is the correct size battery need to be in stock location?
Old 10-11-2024, 04:33 PM   #17
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Iv'e been running a single 11 lb. Braille 12v lithium with an alternator for years. No issues .
Old 10-12-2024, 09:26 PM   #18
SS3860
Liked 175 Times in 58 Posts
I've been using 2 of the Odyssey batteries with no issues. They are 2 years old now. Keep a maintainer on them and only charge at low amps. Not crazy about lithium ion batteries.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
Old 10-15-2024, 01:49 PM   #19
65signet
Liked 49 Times in 22 Posts
My XS battery works great, use it in two different cars, and never put a battery charger on all weekend of racing. weight is about 23lbs
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 10-15-2024, 01:58 PM   #20
Tony Fagnilli
Liked 214 Times in 46 Posts
Originally Posted by 1320racer View Post
The OP said?
The OP said, Looking for a lighter battery option but not interested in lipo/life type.. Any recomendations?
Yet, your response is, not worth the $ nor effort, nothing to be gained on the time slip.
So, that's some irony if I've ever seen it.
Tony Fagnilli is offline   Reply With Quote
