Old 10-18-2024, 10:19 AM   #191
JGrossijr
JGrossijr's Avatar
Liked 463 Times in 60 Posts
Default Re: ET with and without wheelie.
It's worth noting that 60' beam placement is normally about 10" above track. In this position it's not only the front or rear tire that can trip the beam. Depending on how the car leaves it may not even be the same location on the tire tripping it every time.
JGrossijr is offline   Reply With Quote
Old 10-18-2024, 10:28 AM   #192
Doug Hoven
Liked 869 Times in 165 Posts
I'm having a very hard time understanding this 60ft change to ET change thing. Now, if you were to tell me that your car slows down in ET with a big wheelie, then yes, I would agree that you are going to have a slower 60ft by tripping the beam with a different part of the car, and you'll have a slower ET because that's how the car acts. However, to say that the 60ft clock itself has an effect on the ET, that is what I can't figure out. Bear with me, I am just a "kid," but the timer is activated once the starting line beams are broken, and as each photocell down track is "tripped," the corresponding time from the start is recorded. And the MPH works by finding the velocity given the time to travel between the speed trap and the corresponding ET trap. If a car were not to slow any ET by tripping the 60ft clock with either the front or ear tire, the 330 time should be the same. What will change is the 60ft - 330ft interval. Sometimes intervals can show some interesting things.
1189 F/SA
Defunzalo Racing Enterprises
Doug Hoven is online now   Reply With Quote
Old 10-18-2024, 10:45 AM   #193
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
This^^^^^
Especially on a car that sits lower in the front to begin with. Depending on where i come down from the wheelie it could be the front bumper, it could be a header collector, it could be the door. In my opinion, the 330 time is a more accurate measurment of how quick the final ET will be.
Jason Shepard is offline   Reply With Quote
Old 10-18-2024, 10:53 AM   #194
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
as I've stated numerous times here
it's not for those that don't adjust their wheelie for changing weather throughout the day as I do. My car breaks the beam exactly at the same location EVERY pass, evident by not only photos and videos but the time slip that shows a few thousands variance in 60 foot over the entire event!
That said,
how many replying here have the car that can no mind have done an A-B-A with their car on the same day, letting it fly, breaking the 60 foot beam with the back tire then tie down the front, shock extension on full tight, travel limiter set for the minimum tire drop an make a pass with no more than a few inches of day light under the front tires?
We know Stan hasn't as well most others replying here!
Old 10-18-2024, 11:01 AM   #195
TOSTO RACING
TOSTO RACING's Avatar
Liked 663 Times in 187 Posts
I have, but you called me clueless . I'm not saying your car or my car is the right or wrong way just showing different sides of my real world experiences. And that every car is not the same. My timeslips prove in my situation my car does not slow down, it runs about the same et big wheelie or little wheelie . Now my car tied down is way slower to the 60' for some reason.
I have also caught something like the front bumper before or the deflector etc. from a bounce , and have had a faster 60 foot and a slower 330' just different examples 60' can change and car still run same number because where the 60 foot is catching the car like explained above.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 10-18-2024, 11:03 AM   #196
1320racer
1320racer's Avatar
Post your A-B-A time slips from the same day where you have done what I stated. I'd also like to see a photo of your shocks and limiter
Old 10-18-2024, 11:09 AM   #197
Race Clean
Liked 129 Times in 53 Posts
Originally Posted by 1320racer View Post
Post your A-B-A time slips from the same day where you have done what I stated. I'd also like to see a photo of your shocks and limiters.
I know your mission is to get clicks on the site for the boss but just give up on this and go to another thread.
60 foot times means nothing to a stock suspension when you do big wheelies,330 does
Stop global whining
Race Clean is offline   Reply With Quote
Old 10-18-2024, 11:15 AM   #198
1700camaro
Liked 226 Times in 115 Posts
I don't have nor done the A-B-A same day test. Seeing you are so passionate on the subject. Share your A-B-A time slips from the same day.
1700camaro is online now   Reply With Quote
Old 10-18-2024, 11:22 AM   #199
TOSTO RACING
I posted my experiences earlier. And have talked about it. I honestly am done here. If I ever see you at the track you are more than welcome to look at all my data and car anytime .
5664 GHI/SA
Old 10-18-2024, 11:26 AM   #200
1320racer
1320racer's Avatar
so you can't, no surprise. You should have been done with this thread along ago.
