#11 |
Liked 85 Times in 26 Posts
Good evening. Adger, I'm curious about your results with this, assuming you got yours programmed. I have a 98 3500HD, 454 with older whipplecharger. Swapping the computer out and the shop working on it says it's running like crap. They feel it's due to the stock tune not working with the supercharger. I'm looking for someone that can help my guys get this thing under control.
William Kilduff 1970 Barracuda (still trailer jail, indefinitely?) 1968 Camaro SS/C Last edited by BTR69; 10-24-2024 at 11:29 PM. |
#12 |
Liked 880 Times in 311 Posts
After I bought my low mileage 2002 8100 WD 3500 I had some serious health issues and have just been using it between the house and farm. (no racing.. 44' LQGN sitting.. Just toating the Kubota) Soon after I got it in 2016 I noticed some issues with it missing and sometimes it died. I changed to the updated Crank position sensor and all problems went away. I have made a couple long trips in it. The longest from NE Texas/SW Arkansas to Minnesota. April of 2023 I delivered an engine to Ringgold Ga. while I was there I stopped at RED and Ronnie loaded down my 30 ft goosneck with 36 SBC engine blocks and several BBC blocks. It did well going back to Texarkana. Loaded and at Interstate speeds it averaged 9.75 MPG on the way home. I had a tune that ED Wright had sent to me, but had a comuter crash and lost it.. that was just after we had lost Ed. This truck really has served me well. It is nearing 58,000 miles on it. I still plan on doing some mods to it, but I just haven't taken the time.
Alan, I was wondering if you still had that 8100 engine and Trans I delivered to you. If anyone has an update on the tuning of the 8100 let's keep this thread going?
Adger Smith (Former SS) |
#13 |
I looked online into the Black Bear that Alan mentioned earlier in this thread. I've also been questioning others recently on this as well, and I've been hearing about 0411 PCM swap. Seems more folks prefer the 0411 to Black Bear. According to folks I spoke with today, it's more user/tuner friendly. I was advised to get a base tune, then get to a chassis dyno for a more specific tune. I'm pretty computer illiterate with these things, so having to rely on others for this project. Really hoping this gets the truck squared away.
William Kilduff 1970 Barracuda (still trailer jail, indefinitely?) 1968 Camaro SS/C |
#14 |
Liked 52 Times in 22 Posts
Kevin Winstead at Big Dog Tuning may be able to help.
#15 | |
Guest
Posts: n/a
If you can get an Allison trans I?d do that. If a fireman can?t break them they are bullet proof! |
#16 |
Barry,
Mine has the Allison 1000 series With my load and the "Tow" button on the shifter activated I have never seen the Trans temp gauge go high, even with the load of engine blocks. I'm assuming the trans temp should stay under the engine water temp. Water temp is never over 210. I really like the Transmission braking feature of the Allison. I think the up shift points are a little high, even when not in tow mode. I've been thinking about doing a Transmission & rearend service this winter. I have read up on the transmission and seems like they use a special fluid. I've been using AMSOil in my other trucks and was considering making a change. The truck had a Quaker State Sticker on it with mileage for changes. I have used Q-state on all my changes. There is a little more oil consumption than I like...Thinking about making a change and see what happens.
#17 |
Pete Perry look what I found:
CHEVYHD496 619 posts ? Joined 2009 #7 ? Aug 21, 2011 be careful with the drive by wire tables. some trucks the throttle will hang open 02' Chevy 2500HD 496
Adger Smith (Former SS) Last edited by Adger Smith; 10-26-2024 at 04:22 PM. Reason: sp |
#18 | |
I had mine serviced and flushed recently and switched to the Transynd 668 fluid. The shifting improved dramatically with smooth and firm shifts. |
#19 |
Liked 16 Times in 11 Posts
There?s a place in Perkasie Pa that might do it.
That is not far from Maple grove I think. I?m not sure the would do a shipped in ecu though. |
#20 |
I used Rocket Chip on my 8.1L motorhome. Saw improved torque and throttle response. $99 and plus into the OBD port very simple.
