Liked 1,821 Times in 425 Posts
If nothing else is gonna change
We need MINESHAFT RULES BACK This small adjustment will benefit everyone that?s fast and slow Let?s Go
james perrone 1290 STK |
Liked 1,926 Times in 579 Posts
I agree and make it a function of the weather. Maybe DA less than 500ft and baro of 30.0
Mike Pearson 2485 SS |
Liked 419 Times in 85 Posts
Liked 506 Times in 116 Posts
I totally agree.
68 Chevy11 327 F/S |
They could have an adjustment factor the Same as they use for the index at altitude corrected tracks. Or just get rid of the altitude correction all together. Then the fast guys could run all out at the higher altitude tracks. I race in the SE so we don?t have any high altitude tracks here. I do agree to bring back the mineshaft rule. Here in Fl we can see DA in the minus readings and baro above 30.30 in the late winter AMS early spring at Orlando and Gainesville. It?s rare though. Typically that type air is 2-3 tenths faster than usual air.
#6 | |
When the weather is killer, that?s when you need mine Let?s go back to what we had It only comes in effect when the weather is killer
Liked 223 Times in 73 Posts
Here is why the AHFS doesn't work. No body wants to get HP I get it but when NHRA and the manufacturer give bogus ratings on cars and NHRA swipe of a pen or a drunken night on the keyboard and makes the 302 🚀 rockets ships. It needs to be evened out. Not putting runs in the ahfs is not a solution. The mineshaft and Indy not being in the ahfs also the whole Dutch classic this year you cant fix what everybody is complaining about that the ahfs wont work. Let's go back to yesteryear and let officials come up to you at a race and give you hp, because the way it's going nothing will be solved. I don't believe blanket index change will solve anything. The J K L indexs need to be fixed if there are others like this they would also need to be fixed. We need a couple get out of ahfs jail free cards for races on the west coast.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 1,826 Times in 414 Posts
Yeah, no. Having an individual, basically accountable to no one, have the power to arbitrarily just hand out HP, is absolutely absurd.
A properly formulated system, published openly, is the only way to do it fairly. If people work within the system, well, that's called playing within the rules. If you're looking for a level playing field, where everyone is always equal, you ain't gonna find it.
Alan Roehrich 212A G/S |
#9 | |
Liked 1,187 Times in 338 Posts
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Let the qualifying sheet tell you it?s mineshaft
Not the weatherman Weatherman like politician can?t trust them Also 120 under get an instant hit Make class racing great again
