View Poll Results: Should roller rockers be allowed on all stockers?
Yes 113 53.81%
No 97 46.19%
Voters: 210. You may not vote on this poll
Old 05-27-2008, 04:53 PM   #31
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Roller Rockers in Stock
The Isky ductile iron adjustable rockers have no advantage over the stock Max rockers. Both measure around 1.47. I have two sets of these and still run the same 1963 rockers I got with a stock Max engine in 72, Paul.
Old 05-27-2008, 06:02 PM   #32
Jeff Lee
Jeff Lee's Avatar
Don't forget your MOPAR buddies that also get to run the Isky parts as a replacement to their 318/340/360 engines factory equipped with stamped steel rockers. I think you would agree there is a considerable durability advantage in using those Isky's over stamped rockers.
Jeff Lee 7494 D/S '70 AMX
Old 05-27-2008, 07:54 PM   #33
Jeff, Holroyd's rockers are STOCK GM, the studs and adjusters are similar in material to the ARP rocker studs.
We can get by with the 7/16" stuff, there are even some fast cars still using 7/16" rockers. What we broke 2 years ago at Gainesville was an ARP rocker stud, it broke at the base of the threads. I was going to upgrade to the ARP Pro Series studs when a friend turned me on to Holroyd's stuff.
The rockers themselves will still fail the same as the 7/16" rockers, ask a couple of the real fast guys.
If you are willing to replace the rocker studs often enough (the ARP Pro Series studs are $100 or so) you can run the stock diameter studs and rockers. You MAY lose a little to deflection.
NHRA allows all engines to run aftermarket studs, and even convert to screw in studs when they were not originally equipped.
Some big block Chevy high performance engines came with 7/16" pushrods. We (as well as most I know) currently use 7/16" straight pushrods and GM guide plates.
Again, I'd LOVE to see a solution for the rocker problem so that guys with the less popular stuff could go buy good parts for a fair price. I DO NOT want to see cars parked.
However, allowing roller rockers will absolutely bring about serious unintended consequences, for the reasons I outlined earlier.
Old 05-27-2008, 08:58 PM   #34
SSDiv6
As long as they do not allow shaft type rocker arms in applications that were not OEM configuration, and they do not allow stud girdles, then there will not be any measurable gain in power, just reliability.
Old 05-27-2008, 09:06 PM   #35
I do not agree. If you take an engine equipped with stock shaft rockers and large diameter lifters, and replace the stock shafts and rockers with 8620 or 8740 shafts and big roller rockers, you can EASILY exceed what can be achieved with stud mounted rockers and no stud girdle, even WITH roller rockers. Otherwise, there's be no market for stud girdles, and there'd be no shaft rocker conversions.
Old 05-27-2008, 09:44 PM   #36
SSDiv6
Alan, there are only a few applications that use the shaft rockers: Mopars, Ford FE and Buick. The Mopars, both big block and small block, and the Ford FE's, are already running aftermarket adjustable iron rockers made by Isky or Crane. They are not stamped rockers like most OEM configuration. For Mopar applications, you can get a hard-chromed shaft, made of a heavier material that will not flex, at your local Mopar dealer over the counter. The Isky and Crane ductile iron rocker arms do not flex.
By the way, both the Mopar and Ford FE's, already have a big OEM lifters, and they also are fast.
Old 05-27-2008, 10:02 PM   #37
I'm well aware of that. In fact, going back a few years, I was working on a Tunnel Port in a Shelby, and I learned VERY quickly about the strength difference between the stock replacement style rockers and the aftermarket roller rockers. There is a major difference, at least in my experience.
Old 05-27-2008, 10:30 PM   #38
Alan Warman
Originally Posted by gofastorgohome View Post
This poll should be in the competition member section. If you don't have a $15,000+ engine to blow up and oil the track delaying everybodys racing, you shouldn't vote in this poll. The train left years ago as far as what was stock.
So why do you need to spend 15,000 on a motor.There are a lot of racers that don,t have that much in there car.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 05-27-2008, 10:49 PM   #39
gofastorgohome
Talking Re: Roller Rockers in Stock
I was refering to competitive A/B/C cars. Sorry for not being specific.
What movie was that? "There is nothing stock about a stock car..." LOL
gofastorgohome is offline   Reply With Quote
Old 05-27-2008, 10:51 PM   #40
Todd Hoven
Guest
Posts: n/a
And some of those guys are the guys that bitch when there car isn't fast. They don't work on them and they want rules changed so it is easier for them to compete with the guys that put in double the effort and money. If you take the time to learn and work hard you can build a combo to run fast for less, but if you know nothing and don't want to learn then you are going nowhere.
