Old 10-25-2018, 06:31 AM   #21
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
Default Re: Davis step headers
Looked over a set of headers that Ben Line from Minnesota built and the craftsmanship was incredible. I certainly put him in the mix.
XSTOCKER is offline   Reply With Quote
Old 11-09-2018, 01:29 PM   #22
rod
Liked 20 Times in 15 Posts
info on Greg at REF [Race Exhaust Fab] in Kingman, AZ.
phone 928/692-0111 Fax at 928/692-0803
since I live here, I have been to the shop a lot. sometimes I go just to watch. the headers he builds are always as symmetrical as possible. plug access is always a top priority. he built me a beautiful set of merge collectors that knocked off most of a tenth on my old P/S 56. and Robbys welds are like an artist painted the on! you can get std. steel or stainless.
you wont get jerked around here.
Rod in AZ
rod is offline   Reply With Quote
Old 12-01-2024, 06:47 PM   #23
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
I don't have stainless headers but I saw Jon Kasse on YT I think saying that he has seen rust particles on top of the throttle blades! His assumption is that there is enough pulsation to move a rust particle from the header to the carb. I could see a backfire doing it. Here in the rust belt every first start of the season leaves lots of rust on the floor. He actually suggests a starting sequence where you get to 3000-4000 rpm as fast as you can after the engine lights. In my mind this adds an important reason to go stainless. I just curious are they building with 300 series stainless or 400? Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 12-02-2024, 08:27 AM   #24
Billy Nees
Look into Electroless Nickel Plating!
Billy Nees 1188 STK, SS
Old 12-02-2024, 09:09 AM   #25
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
The only reason to go with stainless is weight savings but don?t expect the weight savings of stainless headers over mild steel to show anything on the time slip.
Old 12-02-2024, 12:42 PM   #26
dragracerray
Billy I never thought of that. Does the plating flake or discolor? I would think this would be a method to brand new headers and not used headers?
Merry Christmas, Ray
Ray Bassett
Old 12-02-2024, 01:11 PM   #27
Mark Ugrich
Liked 71 Times in 38 Posts
There are more reasons than weight savings to use a stainless header.
Old 12-02-2024, 01:25 PM   #28
1320racer
1320racer's Avatar
There is not. Stainless also looks like shyt when it heat cycles and is prone to cracking.
Old 12-02-2024, 01:43 PM   #29
Billy Nees
The people who I deal with will only do new headers. I don't know about other outfits. It doesn't flake but it does discolor just like a stainless header. IMHO, much better than any ceramic coatings that I've dealt with. Not saying that all ceramic coatings are bad.
Old 12-02-2024, 02:14 PM   #30
1320racer
1320racer's Avatar
The best at applying ceramic coating to headers is Central Connecticut Coatings. Gene has been coating my headers going back 30 years. His coating has never failed in any way. He also does powder coating from full chassis to the parts.
