Old 12-08-2024, 08:05 PM   #1
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
Default 1966 Chevy ll clutch linkage help..
I have a Super Stock Chevy ll,will be a street strip car for now
SBC with T10 crashbox
Has not been a stick car for many years-I purchased all new stock style reproduction pedal and linkage as a starting point since i had nothing or previous Chevy ll experience..
Car is not quite running yet.I have it all assembled and thought it looked super flimsy and has poor geometry.
It has a fairly stiff non-adjustable Ram clutch-I have only pushed the pedal half a dozen times-the pedal to bell crank bar has already bent!
I guess it would make good sense to replace the upper and lower rods with round tube with rod ends...but any other experience/thoughts?
Thanks
Dom
chopperloco is offline   Reply With Quote
Old 12-08-2024, 10:33 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: 1966 Chevy ll clutch linkage help..
I would look into an adjustable clutch.The operating pressure would be much lower and reduce the stress on the linkage.
Old 12-09-2024, 12:22 PM   #3
1st question here:
What bell housing are you using?
Old 12-09-2024, 03:54 PM   #4
Dirk Olson
Liked 172 Times in 46 Posts
Thanks
Dom
Unless you are using a Chevy11 block you need to modify the bell crank the get the geometry right. If you are using a non Chevy11 block you will need to make a plate for the pivot ball and start from there. heims are always better but a little more work. Good Luck
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 12-09-2024, 07:34 PM   #5
Dave Casey
Liked 804 Times in 168 Posts
Raced a 66 with a stick for years, it is all just ratios/geometry. The setup I used was, conventional bellhousing, a straight bellcrank, NOT a chevy II curved one, and a small plate that the pivot ball was bolted to that had a bolt that went into the factory pivot ball hole on a non chevy II block. Since you bent the rod from the pedal, I would start on the other end. First I would see if you can gain some at the clutch fork, get a longer one if that is possible to make things move easier. Then move to your lower arm of the bell crank, and make it a little shorter. These 2 moves or just one will take some tension off the upper end. All this must be done while making sure you still end up with enough throwout bearing range to operate the clutch.
I believe that the clucth fork will want to hit the floor on the end, an adjustable pivot ball in the bellhousing will help, also you may need to try different height throwout bearings
Chances are the clutch setup is fine, you just need to fix the geometry.
Dave Casey 1330 STK
Old 12-09-2024, 11:06 PM   #6
chopperloco
1st question here:
u
Chevy ll Lakewood scatter shield , the 7 o'clock one
Old 12-09-2024, 11:08 PM   #7
chopperloco
I do have the relocation bracket for the non Chevy ll block
Old 12-09-2024, 11:12 PM   #8
chopperloco
Thanks! Oddly enough it looks like that's how it had been done when it was a C/SM car!
Do you remember which bell crank you may have used?
Dom
Old 12-09-2024, 11:25 PM   #9
u
Okay , you'll need a 9 o'clock bell, if you want to get rid of that Z .bar contraption..
We built several stick Chevy II's in the 70's/
Our team mate, Joe Moon DeLorenzo designed the set up.
Duffy even sold a few sets in his catalog.
It's not real hard .You start with a 1st gen.Camaro cross shaft, and narrow it about an inch .
The afore-mentioned block bracket is from a a 69 C series truck.
I'll help you if you decide to go that route.
Old 12-10-2024, 02:15 PM   #10
Dave Casey
Mark has it right, I never had the pivot ball bracket Mark showed. Mine was 3/8 or 1/2 " thick and only used the hole closest to the ball and it was made so it would rest against the boss in the block and not turn or move. I don't know what my bell crank started life as, but a camaro one should work once it is shortened.
Dave Casey 1330 STK
