Old 06-01-2008, 01:45 AM   #61
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Default Re: ATTN Sportsman Council Members and Racers
So lets just say N.H.R.A. drops all indexes by .2 so that the guy now running -1.39 is -1.19. But he will no longer be on the brakes cause he wants do be # 1 qualifier so his car is now -1.35 & close to be getting hit again if he is not careful. What now?
Would someone please tell me what the problem is with getting rid of the trigger or lowering it to say -1.6 & leaving the indexes where they are? That way the fast guys could go hard all the way & still qualify near the top where they do now. The guys at bottom are unaffected.
55 Chevy is offline   Reply With Quote
Old 06-01-2008, 07:46 AM   #62
Bruce Noland
Liked 444 Times in 145 Posts
-1.60 for an automatic hit does not help class racing because the trigger for reviews is still -1.15 at national events.
99% of all the races are all-run events. The slower racers still have at least three options on the lower indexes; not in any particular order.
1.) Work on your car.
2.) Pick another combination.
3.) Seek relief from the current ahfs god if you are really into a dead end combination.
Bruce Noland 1788 STK
Old 06-01-2008, 07:46 AM   #63
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
Plus NO ONE is watching the qualifying sheet lately, The guys qualifying at the top are mostly modified cars now. The guys that can go 140 plus.(MPH) Soon this will be dominated by comp cars. Something else for you guys to bitch about. No one will ever be happy. By the way, SS engine guy, who are you, and what car do you run? By the way, you wont find my name on a qualifying sheet, so dont ask.
Old 06-01-2008, 11:10 AM   #64
Arnold Greene
Liked 3 Times in 2 Posts
First of all, I haven't raced NHRA in three years, so my opinion doesn't count for much. It appears to me that the burden(ahfs) in stock and superstock is being placed on the wrong group of people. Why should someone be penalized for using the rules, determined by the sanctioning body, to go fast? This is the goal in a performance class. If a combination in a particular class is deemed not competitive, then take 5 horsepower (or whatever # is deemed appropriate) off the combination. Let these folks work at that weight to get competitive just like the fast guy had to work. Don't just add weight to slow the fast guy down. That's how we ended up with 3700# Camaros and Cudas.
Like some have said, class racing may not be for everybody. It is not a 'right' to be able to run the index, much less, go fast. The way the system works now, you might as well do away with the class designations on the windows, and just put on the dial in.
Arnold Greene
IHRA/NHRA 2420 A/S, B/S
Arnold Greene is offline   Reply With Quote
Old 06-01-2008, 11:46 AM   #65
Larry Munk
How about this one. Lets do like was done before. No car older than 15/20 years old in stock. All the antiques can go to super stock or the car shows. Put the comp cars where they belong. And while you're at it drop the indexes .4.
Larry Munk is offline   Reply With Quote
Old 06-01-2008, 01:15 PM   #66
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs down Re: ATTN Sportsman Council Members and Racers
Larry,
Why don't you just say you only want GM cars in competition? Then they can dominate Stock as well as Pro Stock. Comp, and Super Stock. Won't be any need for factors then huh? Jim
Old 06-01-2008, 02:18 PM   #67
Lynn A McCarty
Lynn A McCarty's Avatar
Bruce,
You miss the main point of your own premise. How much must you hit to bring a 1.6 under combo into check? I know one engine that has been hit 45HP since 1996. It is still one of the softest combos around.
The real issue is that AHFS is better than nothing, but it really doesnt address the real problems. It is statistically invalid, and statistically ineffective for the gross inadequacies. If a car runs 1.6 under and it isnt grossly done in a mine shaft, it probably should get at least 30HP or 40HP.
Do you know how bogus an engine has to be average 1.15 under? All events follow a 6-sigma spread around the average. So that means 1/2 the cars run faster than 1.15 under? How truly bogus!
The current system is wrong and needs to be changed. I have described some appropriate measures many times.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 06-01-2008, 02:18 PM   #68
Larry Munk
Actually Jim I'm a Ford guy. They still make a rear drive car.
Old 06-01-2008, 02:23 PM   #69
Jim Wahl
Jim Wahl's Avatar
Talking Re: ATTN Sportsman Council Members and Racers
Me thinks there was a dig there somewhere. I'm used to that kind of thinking. jim
Old 06-01-2008, 03:59 PM   #70
Chad Rhodes
so does GM
Chad Rhodes 2113 I/SA
