#41 |
Liked 508 Times in 92 Posts
Maybe Nhra should rename Stock eliminator to "Bracket Stock Eliminator" ?
#42 |
Liked 759 Times in 379 Posts
So the “fun” is gone when you don’t push/pull your shifter twice?
If that is true, the easy solution is don’t use an air shifter but I’ll bet most of your competitors will. ![]() Last edited by 1320racer; 03-07-2025 at 06:16 PM. |
#43 |
Liked 497 Times in 243 Posts
#44 |
Liked 544 Times in 213 Posts
Pro Stock racers were using air shifted transmissions years ago.
It was knocked out by NHRA Some manual trans comp cars use air shifted 4 and 5 speeds I believe I personally don't have a problem shifting my car manually but as I said..... racing 1/8th mile makes it more of a dis-advantage. If you drive a slow car that does not wheel stand......it's a non issue... If you choose to race a stick shift car and it's fast, you're already at a big disadvantage....your choice.... Stock eliminator IS BRACKET STOCK.....Sure there are heads up races but it's primarily a dial in with a breakout form of racing.....been that way for years and years.... If you want to win, you use whatever equipment that can help and is allowed. If you can afford a killer fast driveline so you are the fastest car in the class, it's the same thing.....You bought what can win for you...
#45 | |
Rich Biebel…KNOWS! Last edited by 1320racer; 03-08-2025 at 09:11 AM. |
#46 |
LOL...
#47 | |
Liked 2,360 Times in 558 Posts
The easy solution is to leave the rules alone and quit catering to the weenies of the world. If they need automatic shifting and can't figure it out within the current rules, THEY should do something else....
Daren Poole-Adams NHRA Stock/SS 2007 |
#48 | |
Liked 148 Times in 54 Posts
Ah, yes. They are doing something else and they tell us it's the future of our sport remember?
I can see the future already, tons and tons of Junior dragsters with no gear shifting.. Better get yourself one before you're left out. Quote:
#49 |
Liked 231 Times in 107 Posts
#50 |
As you stated, your opinion. Meanwhile, I’ve spoken to numerous stock eliminator racers whose opinion is changes such as this are welcome and more is needed to save the class. Like it or not. Stock eliminator is bracket stock as Rich has stated.
