Liked 11 Times in 4 Posts
Hi, can someone tell me the class that best fits a 1963 Dodge 330 wagon with the 383 4-bbl engine? I have an idea, but want to make sure I'm coming up with the correct class from the stock car classification guide. This build will be for Stock eliminator racing. Thanks! -Mark
Liked 168 Times in 30 Posts
go to class racer info, everything you need is there.
Liked 10,819 Times in 2,248 Posts
Look at minimum wt of natural class with driver and national Index. Do the math to get car to the next class both heavier and lighter and see if the weight change will give more or less index. Way easier to add weight.
Liked 1,471 Times in 308 Posts
Two questions need to be answered to properly classify your car. A) is it a
6 or 9 passenger wagon, and B) are you going to run the 383/305 HP combo, or are you going to run the 383/330 HP motor? J.R. |
I believe its a 6 passenger wagon, I want to run the 383 with the 4bbl. I think that would be the 330 hp?
Liked 2,741 Times in 967 Posts
E, F OR G.
Liked 327 Times in 121 Posts
Your weight factor is 12.23 so it's a natural I car and you can run H I or J, the NHRA rated HP is 292 for the four barrel. Other than the very small AFB and lack of V to P clearance it's a pretty good package and the wagon has a 116 wheelbase where as the non wagon is 119.
Liked 258 Times in 49 Posts
It's an uphill battle but don't forget about the expensive aftermarket aluminum heads rated at 285 hp.
Liked 781 Times in 195 Posts
Thanks to all that posted! I think I got it figured out now. I see where I/SA is a good fit as I been told, 383-4-bbl combo. 3640 lbs. Thanks to all again!
