Liked 6 Times in 5 Posts
Hey guys I know this is the age old discussion but besides the normal tire psi, weather, log book etc what do you find that affects consistency of a car. Unfortunately I have literally tried everything and used every variable to find out what affects my car on race day with no success. I know y?all don?t wanna give away any secrets but any insight into direction would be appreciated. I?m literally down to deciding wether the air in the engine compartment is causing issues
#2 | |
Liked 1,226 Times in 343 Posts
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 308 Times in 103 Posts
Everything on car can be great, but without good seal, rings and valves and good balancing +/- 1/2 gram is my tolerance.
a good tune up is crucial too. A good flat and wide HP and TQ(especially tq) curve make it easier without those you will never get deadly consistency. |
#4 | |
Liked 1,943 Times in 584 Posts
Mike Pearson 2485 SS |
Don't forget the temperature of your fluids (oil, trans, etc.). My car is good for .04-.05 just from the oil being really hot. When you're in the later rounds, you've got to remember to account for that.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
So I run a 402 375 horse combo in a 70 chevelle weight is usually 3810 my minimum is 3635. It?s got a Tilburg motor with a Sepanek metric 200. I try to keep all my fluids everything the same temperature before the run so on and so forth that?s why I?m trying to figure out if it?s a fueling issue through the carburetor or something that I?m not looking at correctly.
#7 | |
Liked 253 Times in 95 Posts
Nick, what I would do is go to a track rental and try to make 3-4 runs within 2 hours, don?t make any changes and see if the car repeats. This will take the weather factor out of the picture, but watch the wind. If the car repeats the car is good, probably a fuel or carb issue. If it?s changing run to run, see where the inconsistency is. 60? could be suspension, mph could be fuel. A good trans and carb can make all the difference. I?ve have ones that just won?t do the same thing twice. We expect incredible things out of our cars. .02 of a second is so little but so important.
George Mirza D/SA 1236 ‘71 Duster 340 |
#9 | |
#10 | |
