Old 05-01-2025, 08:21 PM   #11
1700camaro
Liked 226 Times in 115 Posts
Default Re: Consistency
Originally Posted by Barso1514 View Post
That?s the plan and my 60? are within a thousandth. I do think I was fighting front springs which are changed. I try to be 100% consistent and deliberate with everything I do. But I?ve read a lot on the air inside the engine compartment being hotter then ambient will also play games with it. Luckily dad has the factor sealed cowl air cleaner that seals to the hood I?m gonna try that see if there is any truth to it
Inconsistencies can happen other than your 60's, as you probably know. I would start by looking at your split times down track.
1700/STY/781L
You earned/deserve the vast majority of unfriendly & different names earned by you due to your BS. Embrace them names, they're the Real Truth.
1700camaro is offline   Reply With Quote
Old 05-01-2025, 09:36 PM   #12
a pontiac
Liked 36 Times in 11 Posts
Some cars with oem hood scoops do not get enough air. Have you tried bare carb or air cleaner base only? What you may lose to heat is offset by more airflow.
a pontiac is offline   Reply With Quote
Old 05-01-2025, 10:54 PM   #13
CMcAllister
Liked 920 Times in 259 Posts
Some combinations - low compression, small cubes, heads, big, heavy, etc - are just effected more by weather changes, humidity, wind, and plenty of other variables.
If it 60's consistently, and you keep up with maintenance, keeping up with the conditions and knowing how the car reacts to them, is critical.
My car - small cubes, low compression - would be killed by humidity, or helped by a lack of it, and the weather station and software wouldn't adjust for it. Some fudge factoring was needed to compensate.
Old 05-02-2025, 06:40 PM   #14
SS3860
Liked 173 Times in 58 Posts
So I have pan heaters for trans and motor. I have a race air cloud with their race base software. I definitely do not cheap out on things. I try to buy the best of the best as long as I can afford it. I just put a grid in it to help slow it down because at minimum I?d do more harm then good due to the old ahfs
I used to bracket race with a grid. Found car was more consistent running with the proper timing and at peak power than pulling timing and slowing car down. Now if you're using the ARC module dot to dot that's a different story.
Tom Flowers
E/SA 3860
SS3860 is online now   Reply With Quote
