Old 04-20-2025, 10:34 AM   #101
John Dinkel
Liked 265 Times in 69 Posts
Default Re: New shifter rule poll
Been pushing buttons in my Max Wedge since the 70's . Wouldn't have it any other way.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 05-13-2025, 12:49 AM   #102
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
What differences are there between using a air shifter or not using one ?
Jake Biermann
Old 05-13-2025, 01:02 AM   #103
doglover44
doglover44's Avatar
Originally Posted by JP1738 View Post
I'm with you guys on 2-steps, no idea why autos have them. I do not use one and I'm honestly not sure why I would need one.
Didn't know you don't run a 2 step !
Jake Biermann
Old 05-13-2025, 11:11 AM   #104
JP1738
JP1738's Avatar
Liked 1,339 Times in 364 Posts
sure don't. That's just one more thing that can't go wrong in my operation.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 05-13-2025, 12:17 PM   #105
curtis reed
Liked 126 Times in 60 Posts
Not shifting with your hand / shifting with your hand.
curtis reed is offline   Reply With Quote
Old 05-13-2025, 01:11 PM   #106
MoJo Risen
Liked 148 Times in 54 Posts
So like you blow on it instead of moving it with a arm movement?
MoJo Risen is offline   Reply With Quote
Old 05-13-2025, 01:23 PM   #107
curtis reed
Well if you can blow that hard go for it.
Old 05-14-2025, 01:04 PM   #108
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
That's a big NO for me in Stock Eliminator
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-14-2025, 01:48 PM   #109
SDmopar
Liked 231 Times in 54 Posts
What a time we live in where how you shift your automatic transmission becomes such an emotional trigger.
Seems simple run a stick if you want to shift every gear yourself. Run automatic if you want the option to do it either way. I could care less on how my opponent does it. Blocking, shifting or stripe takers still won?t help racers who struggle. I?d prefer every one of my opponents have an air bottle. It?s one more thing that can go wrong with there run. Stripe takers will lose more runs then they will help with. Blocking is a great tool but you better be able to switch back when it gets dark. I understand the purity aspect of Stock Eliminator but her virginity was lost when we started allowing aftermarket components. I?m not the brightest bulb but I?m pretty sure edlebrock heads never came from the factory. Same could be said for Caltracs, afco shocks. Now that I pissed off everyone here let?s just realize there is nothing stock about what we do now and join together and support any group that tries to give us a place to compete. Instead of hassling and bitching about every detail.
Brian Anderson
5058 B/SA 99 Chevy Camaro SS
SDmopar is offline   Reply With Quote
Old 05-16-2025, 01:35 AM   #110
Casey Miles
Liked 508 Times in 92 Posts
So you start out with an automatic transmission, then you turn it into a manual transmission. Now you want an automatic shifter, why not just turn it back to an automatic, shifting problems are solved. You don't need to move that lever to change gears anylonger.
Casey Miles
248H E/S
