Liked 1,002 Times in 203 Posts
Working on a 78 G body car. What is the best, and most economical way to change it to manual steering?
Liked 708 Times in 285 Posts
I did the standard rebuilt Vega box. Speedway has a box now. S10 is just a little bigger and safer to use then the Vega due to weight. I've had mine for about 12 years.
Liked 323 Times in 63 Posts
I used S10 boxes on my El Camino.Regal,Monte Carlo, and Seville. No modification needed.
Bob Shaw V/SA 515 |
Liked 26 Times in 12 Posts
S 10
I see that Speedway has one the call the "drag racing conversion box" Do you need to get the one with the pitman arm,or will the stock pitman arm work? Thanks for the info.
I believe it's same spline for stock arm. They also have straight arm or I think deep bent arm.
Liked 2 Times in 2 Posts
will the s-10 box work on a 67 Camaro?
Yes and no...
The frame bolt pattern hasn't changed in decade in that series. The small pitman arm pattern (non-power) is still the same . Where you might find trouble is in the steering shaft. S10s are metric vehicles.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 06-06-2025 at 09:08 PM. Reason: why not? |
