Old 06-05-2025, 06:26 PM   #1
e vassar
Liked 278 Times in 110 Posts
Default 1995 G.M. factory ECM question
I have a 95 Firebird T/A LT1
It is bone stock except for headers, 3.73 rear gears and ABS has been removed.
I am going to need a ECM. I have seen them advertised from $150 to $800..what is the difference? None that I can see. Some of them get flashed with the receiving vehicles VIN which may be for security systems.
Can I just take an ECM out of any old 95 LT1 Firebird / Camaro?
Thanks...
Old 06-05-2025, 11:06 PM   #2
Liked 5,153 Times in 1,967 Posts
Default Re: 1995 G.M. factory ECM question
Use the same number/letter code (automatic or standard)
Might have to do a learning procedure for that car..(see a shop manual)
Old 06-14-2025, 07:35 AM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Thanks...
Short answer YES.
1995 LT1 uses the GM ODB1 ECM also called PCM.
I have 3 Modified PCM's.
There is a Reluctor available.
1995 Pontiac Firebird Trans Am came with a 10-bolt, 7.5" rear end.
Buying another 95 F Body PCM is good enough for normal driving.
Needs to be tuned for your vehicle.
Especially the speedometer.
The ABS light will remain on in the dash.
Can remove the Bulb.
Opportunity to replace burned out bulbs or upgrade to brighter ones
To do the tuning purchase TunerCat and Cables for your Laptop.
Plus one file specifically for your 95 Firebird.
TC will send instructions to get everything working.
For custom tune, there are several ODB1 Tuners out there.
Can email a Customized .BIN for your car to Download.
FWIW ODB1 PCM are hardwired for a 7000rpm max RPM.
Hope this information helps.
Dan
