#21 | |
Liked 61 Times in 25 Posts
#22 |
Liked 225 Times in 88 Posts
The only thing I learned from a friend who runs a Ford SB is you need a really good pin for the cam timing gear .
#23 |
Liked 398 Times in 153 Posts
It needs to be a GOOD quality bolt, torqued correctly. Most of the good cams already have a larger (7/16) bolt requirement.
The dowel does not keep the gear from moving, clamp force does.
Phil Molski PMR Performance S/C 1623 |
#24 | |
Liked 784 Times in 200 Posts
Bret Velde 2003 I/SA |
#25 |
I?ve got a new Jesel belt drive sitting on the shelf from a past project. Should be fine😁
#26 | |
Liked 275 Times in 76 Posts
Suggesting the guy that bought someone elses car is legal, and not checking it seems risky to me. The lack of a rear firewall would be one of the items I would take another look at on your car. Sean
#27 | |
#28 | |
#29 |
Liked 7,909 Times in 1,754 Posts
I hope that after you get it apart that you can find enough parts to get it back together in a timely fashion.
#30 |
I should have most of it already on the shelf. I?ve been messing with these sbf a long time. I have stacks of new coated bearings, gaskets, new (legal) rods, etc. I already have a set of the valve springs they have listed as being in it. The only thing I don?t have is piston rings, because I need to see what it has now. I also have a brand new ?68 based 302 shortblock sitting here that I was already building when I bought the car. New Boss block, Eagle crank(again the legal one, took me 2 years to find it lol). Good rods and pistons, just no heads yet. Looking for a set of the NHRA legal aluminum castings that aren?t made anymore. I was going to build a car, then this one showed up. So again, not really concerned about getting it back together. This thread got so far off track , lol. I just wanted to know if the carb had to have the exact casting number as listed, or as long as it was the same type, venture size and throttle size, would it be legal, lol
