#11 |
SS Div. 6. I, too, thought duration was the culpret. When you allow the valve to stay open longer it must close rapidly or there could be clearance problems. Doesn't excessive duration cause some of these problems stockers are having? I do know if your ramp design allows for quick closing, the spring pressure has to be increased or that valve will bounce. Wouldn't you say all these things are the root of the rocker arm problems? And then the roller rockers and girdles will solve everything until they remove the stock lift rule then the Jesel system will be necessary. Where does it stop? Your posts are excellent, by the way.
Jesse Knapp 4899 STK, SS |
#12 | |
It is also a function of efficient cylinder filling: you have to take in to account the cylinder head flow, velocity, stroke, rod length, valve size, piston, etc...for your camshaft design. The area under the curve will determine how good your cam performs. One of the biggest problems with the wrong duration and incorrect camshaft events is reversion. I have lost count on how many engines I have seen with this problem. Signs of reversion is a sooty intake manifold plenum and exhaust. Also, when your engine does not respond to jetting or fuel curve changes, most of the times you have a reversion problem. Last edited by SSDiv6; 06-03-2008 at 11:46 PM. |
#13 |
Guest
Posts: n/a
Warren Johnson wrote a great article in the Dragster about this years ago, I'll try to find it and post it.
Chris, Hollow valves that are filled with sodium. It acts like a dead blow hammer when it hits the seat. Use something in the hollowed out area. Use your imagination and then get back with me. |
#14 |
Liked 112 Times in 31 Posts
SSDiv6,
I think you mean EXACERBATE, which is "to increase severity or violence", as opposed to EXUBERATE, which is "to make things happy". Also, I've never seen "overfilling a cylinder" as a problem. If that were the case, supercharging wouldn't work. Jerry |
#15 |
Jerry, thank you for the correction...hard to type after a 15 hour work day!!! In regards to over filling a cylinder as a problem, superchargers and turbos are RPM controlled. Also, they have means to control the excess of pressure by relieving the pressure when they reach certain levels. A normally aspirated engine does not have those means, therefore you use the cam timing events to do so. I spent enough time with the Series I and Series II GM Supercharged engines and saw too many engines blow up when guys changed the settings on the boost control selenoid. Camshafts for supercharged and turbo engines have timing events completely different than the current Stocker grinds, especially in the overlap numbers to alleviate reversion.
#16 | |
Liked 784 Times in 196 Posts
#17 | |
#18 | |
