Old 07-16-2025, 06:20 PM   #1
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Default Flush
What is the best method for flushing the cooling system at home? Trans builder said to flush the system after finding debris in my trans.
J.T. Rose & Associates U/SA T/SA 302R
Rose Racing is offline   Reply With Quote
Old 07-16-2025, 06:50 PM   #2
Default Re: Flush
Most parts stores carry "Cooler Flush", usually, two cans will do the trick to flush a transmission cooler.
Old 07-16-2025, 10:52 PM   #3
CMcAllister
Liked 926 Times in 263 Posts
Default Re: Flush
Kooler Kleen
Old 07-17-2025, 08:25 AM   #4
JP1738
JP1738's Avatar
Liked 1,290 Times in 358 Posts
Default Re: Flush
I don't know if this is good or bad, but historically, I've just sprayed a bunch of brake clean through the lines and blown them out with an air hose. Makes a mess but gets the job done.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 07-17-2025, 12:49 PM   #5
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Default Re: Flush
J.T.,
Trans guy wants you to flush the transmission fluid cooler in the radiator or wants you to flush the antifreeze? If you have debris in the transmission fluid cooler side of the radiator some times it is best to install a new radiator. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 07-17-2025, 02:03 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
Default Re: Flush
I dont know anyone running a cooler on a race car. I never have.
Mike Pearson 2485 SS
Old 07-17-2025, 03:29 PM   #7
pmrphil
Liked 393 Times in 153 Posts
Default Re: Flush
Originally Posted by dragracerray View Post
J.T.,
Radiator cooling lines are just that lines, NO fins.
A plate and fin type cooler should be replaced, tube style can be flushed.
Either one, WAY cheaper than another trans rebuild because of recirculated trash.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
