Old 07-21-2025, 12:51 PM   #1
CraigG
Liked 8 Times in 7 Posts
Default Welding tips and bracing of axle tubes for factory 12 bolt h
Hey Guys,
I am looking for welding tips and bracing of axle tubes for factory 12 bolt housing - where tubes join the pumpkin and as fully assembled or Probably has to be completely disassembled?
Thanks, Craig
CraigG is offline   Reply With Quote
Old 07-21-2025, 02:31 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Default Re: Welding tips and bracing of axle tubes for factory 12 bo
Find a good welder and have the tubes welded to the center section all the way around. Bracing can be accomplished with a LPW cover with the bracing option.
Mike Pearson 2485 SS
Old 07-21-2025, 05:27 PM   #3
CraigG
What successes or limits have others had with a Tubes Welded Ladder bar 12 bolt = limits of factory Tubes strength?
Thanks, Craig
Old 07-21-2025, 06:15 PM   #4
Billy Nees
Unless you're not putting a lot of power through this 12 bolt, I wouldn't use a stock housing. This is from my own personal experience. The axle tubes won't handle lots of power.
Billy Nees 1188 STK, SS
Old 07-22-2025, 10:15 PM   #5
CraigG
Thank you - I will probably get the welding of the tubes and the LWP cover with the brace.
Old 07-23-2025, 10:07 AM   #6
Liked 10,871 Times in 2,255 Posts
Keep an eye on pinion angel if it changes the tubes are twisting.
Old 07-23-2025, 11:03 AM   #7
Billy Nees
Tubes that are welded to the center section shouldn't twist BUT the stock tubes will tear either at the weld or at the spring mounting point.
Old 07-23-2025, 12:02 PM   #8
GUMP
Liked 2,361 Times in 558 Posts
You can probably get good money for the factory 12-Bolt case. Maybe enough to buy a new aftermarket one that won't have the issues that the stock one will.
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 07-23-2025, 09:06 PM   #9
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Go aftermarket, thicker casting and tubes, weld them all the way around and brace it like I did and you'll never worry about it again.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 07-23-2025, 10:37 PM   #10
Liked 5,144 Times in 1,964 Posts
Don't think ladder bars will go on there real easy...;-)
